foreman-nightly-rpm-pipeline 528 failed
Foreman RPM nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/528/
foreman-nightly-centos7-test (failed)
foreman-nightly-centos7-upgrade-test (failed)
[ WARN 2020-04-18T22:09:41 verbose]  /etc/foreman-installer/custom-hiera.yaml: file does not contain a valid yaml hash
[ERROR 2020-04-18T22:09:46 verbose]  Evaluation Error: Error while evaluating a Resource Statement, Class[Foreman::Puppetmaster]:
[ERROR 2020-04-18T22:09:46 verbose]   has no parameter named 'enc_api'
[ERROR 2020-04-18T22:09:46 verbose]   has no parameter named 'report_api' (file: /usr/share/foreman-installer/modules/puppet/manifests/server/config.pp, line: 294, column: 5) on node pipeline-foreman-server-nightly-centos7.n53.example.com
[ERROR 2020-04-18T22:09:46 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/pops/types/type_mismatch_describer.rb:539:in `validate_parameters'
[ERROR 2020-04-18T22:09:46 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/pops/types/type_mismatch_describer.rb:499:in `validate_parameters'
