Foreman nightly Plugins DEB Test pipeline failed:
https://ci.theforeman.org/job/foreman-plugins-nightly-deb-test-pipeline/250/
foreman-pipeline-plugins-deb-nightly (failed) (remote job)
Looks like it was a repo issue. This sometimes happens during repository regeneration.
[2024-05-14T09:12:10.339Z] Failed to update apt cache: E:Failed to fetch http://deb.theforeman.org/dists/bullseye/3.10/binary-amd64/Packages.gz Hash Sum mismatch
[2024-05-14T09:12:10.339Z] Hashes of expected file:
[2024-05-14T09:12:10.339Z] - Filesize:28356 [weak]
[2024-05-14T09:12:10.340Z] - SHA512:e233407e5d51f37f197689fc915aaf6b37dd0bb29c24ae163196f9d5daaae77f9bec7f8aefd773120ea2e5cbc7394298c3d3a8c62c513dca32cd1fd50ab93f60
[2024-05-14T09:12:10.340Z] - SHA256:69e05033feb85a99cecd8f7335b1fd79dc510b23a86992c389cf2cc2b78a70c7
[2024-05-14T09:12:10.340Z] - SHA1:cf0b37393612dd553eb6a61354a7cc0d0403ae7a [weak]
[2024-05-14T09:12:10.340Z] - MD5Sum:e2655b8a3d241d6fa5fe037e9fcb02b6 [weak]
[2024-05-14T09:12:10.340Z] Hashes of received file:
[2024-05-14T09:12:10.340Z] - SHA512:c82edcfcbde46a6a781d07a51a4dfb47f420483e7d11f528f36d5774f730a7fa83fd59a206bb3e20a5e8e893559deed21ba40617294c676c23a04eee06ceac04
[2024-05-14T09:12:10.340Z] - SHA256:7ce3465e153e8e0a0a36ac3f5cc542da33f9cccddd48ac2436182291482d6428
[2024-05-14T09:12:10.340Z] - SHA1:2459c7d38c67ae946b875bc840f9f276d8471531 [weak]
[2024-05-14T09:12:10.340Z] - MD5Sum:10f26e98433441dcf24de74df85e6202 [weak]
[2024-05-14T09:12:10.340Z] - Filesize:28356 [weak]
[2024-05-14T09:12:10.340Z] Last modification reported: Tue, 14 May 2024 09:11:08 +0000
[2024-05-14T09:12:10.340Z] Release file created at: Tue, 14 May 2024 08:34:10 +0000
[2024-05-14T09:12:10.340Z] , E:Some index files failed to download. They have been ignored, or old ones used instead.
