I am trying to figure out how to add a provider for Proxmox and configure it. I haven’t been able figure out the proper way to install the provider and configure it. The process for VMware was pretty simple and straight forward. I have heard libvire is the way to go. Any links for suggestions are appreciated.
Hi @dsexton18
Please have a look at the latest documentation for Proxmox: Provisioning Virtual Machines in Proxmox.
Thanks. For the info I must be missing a repo I added the plugin repo [Index of /plugins/3.5/el8/x86_64](https://Plugins repo)
But still missing a repo I suspect
Problem: conflicting requests
- package rubygem-foreman_fog_proxmox-0.14.0-4.fm3_5.el8.noarch requires rubygem(fog-proxmox) >= 0.14, but none of the providers can be installed
- package rubygem-foreman_fog_proxmox-0.14.0-4.fm3_5.el8.noarch requires rubygem(fog-proxmox) < 1, but none of the providers can be installed
- package rubygem-foreman_fog_proxmox-0.14.0-4.fm3_5.el8.noarch requires (rubygem(fog-proxmox) >= 0.14 with rubygem(fog-proxmox) < 1), but none of the providers can be installed
- nothing provides rubygem(ipaddress) < 1 needed by rubygem-fog-proxmox-0.14.0-2.el8.noarch
- nothing provides rubygem(ipaddress) >= 0.8 needed by rubygem-fog-proxmox-0.14.0-2.el8.noarch
- nothing provides (rubygem(ipaddress) >= 0.8 with rubygem(ipaddress) < 1) needed by rubygem-fog-proxmox-0.14.0-2.el8.noarch
(try to add ‘–skip-broken’ to skip uninstallable packages)
Never mind I figured out the above. When I go to configure Proxmox as a provider I get Unable to save * ERF42-4050 [Foreman::Exception]: Proxmox version Unknown is not semver suitable.
It looks like your using an incompatible Foreman Proxmox plug-in.
You should try to upgrade the plug-in version; looks like you are still using foreman_fog_proxmox 0.14.0 and fog-proxmox 0.14.0 which does not support Proxmox 7.1. See Confirmed support for Proxmox 7.x · Issue #210 · theforeman/foreman_fog_proxmox · GitHub
I tried the latest version 15 from the nightly repo. No joy
I upgrade the Foreman 3.8 now able to add proxmox as a computer resource. I haven’t had a chance to do much testing.
Hi there! How did you figure out the above? I get the same error while trying to install the plugin via the RPM.
What verson are you using? For 3.7 and newer use foreman-installer --enable-foreman-plugin-proxmox
I am using proxmox 8.1 or 8.2 check when i get home.
I am using Satellite 6.15 and want to provision VMs through the plugin. I fixed it by downloading the rubygem[ipaddress] RPM manually.
Do I understand you correct, that dependencies are missing? Are they missing in the RPM spec file?
Best regards Bernhard
I have gone through this post and found it very much useful and informative to be honest. ![]()
