so I set up a new VM and installed foreman 1.1rc5 using the installer which
worked without any error and the web interface can be navigated but
foreman-proxy only returns "connection reset by peer". I tried setting the
log level to DEBUG but no proxy.log file is written at all.
Any ideas what this could be? When I installed foreman 1.0.2 the same way I
didn't see this issue.
Regards,
Dennis
Turns out that the SSL stuff doesn't seem to work. After commenting out
these three lines I no longer get the connection reset error:
#:ssl_ca_file: /var/lib/puppet/ssl/certs/ca.pem
#:ssl_certificate: /var/lib/puppet/ssl/certs/foreman11.local.pem
#:ssl_private_key: /var/lib/puppet/ssl/private_keys/foreman11.local.pem
Regards,
Dennis
On Sunday, February 3, 2013 5:29:07 PM UTC+1, Dennis Jacobfeuerborn wrote:
> Hi,
> which worked without any error and the web interface can be navigated but
> I didn't see this issue.
> Regards,
> Dennis
So now that the proxy is sorted I try to import the environments an I am
greeted with a 500 internal server error. The foreman log says this:
Started GET "/environments/import_environments?proxy=1-local-proxy" for
10.99.0.1 at Sun Feb 03 17:37:30 +0100 2013
Processing by EnvironmentsController#import_environments as HTML
Parameters: {"proxy"=>"1-local-proxy"}
Operation FAILED: 500 Internal Server Error
Rendered home/_topbar.rhtml (1.9ms)
Rendered common/500.rhtml within layouts/application (9.8ms)
Completed 500 Internal Server Error in 165ms (Views: 12.1ms | ActiveRecord:
1.2ms)
The "1-local-proxy" bit looks a bit suspicious to me.
> Regards,
> Dennis
>> Hi,
>> Regards,
>> Dennis
That you had to comment out the SSL configuration directives suggest to me
that you're not hitting the proxy on an https url - if I recall, the proxy
doesn't do a redirect, so you have to be explicit about the
https://protocol in the Foreman Smart Proxy UI page.
As for the Error 500, the logs are fine but uninformative - can you provide
the logs from the proxy when you attempt an import?
