Foreman proxy issue
Hi guys,
do you anyone know, where is problem when foreman-proxy after the running
about 5s is stopped?
Anyone met this issue? Foreman itself works fine.
Thanks
> Hi guys,
What's in the logs?
Ohad
··· On Tue, Oct 6, 2015 at 1:33 PM, Zbynek N wrote:
Thanks
“Foreman users” group.
Dne úterý 6. října 2015 13:00:01 UTC+2 ohad napsal(a):
>> Hi guys,
> What's in the logs?
> Ohad
>> Thanks
>> "Foreman users" group.
>> email to foreman-user...@googlegroups.com <javascript:>.
>> <javascript:>.
>> Visit this group at http://groups.google.com/group/foreman-users.
W, [2015-10-06T12:10:15.846830 #21055] WARN – : Couldn't find settings
file /etc/foreman-proxy/settings.d/foreman_proxy.yml. Using default
settings.
I, [2015-10-06T12:10:15.847248 #21055] INFO – : 'foreman_proxy' settings
were initialized with default values: :enabled: true
I, [2015-10-06T12:10:15.854295 #21055] INFO – : 'facts' module is
disabled.
I, [2015-10-06T12:10:15.854739 #21055] INFO – : 'dns' module is disabled.
I, [2015-10-06T12:10:15.855019 #21055] INFO – : 'templates' module is
disabled.
I, [2015-10-06T12:10:15.855347 #21055] INFO – : 'tftp' module is disabled.
I, [2015-10-06T12:10:15.855682 #21055] INFO – : 'dhcp' module is disabled.
I, [2015-10-06T12:10:16.205257 #21055] INFO – : 'puppet' settings were
initialized with default values: :puppetdir: /etc/puppet,
:salt_puppetrun_cmd: puppet.run, :use_cache: true
I, [2015-10-06T12:10:16.212976 #21055] INFO – : 'bmc' module is disabled.
I, [2015-10-06T12:10:16.213511 #21055] INFO – : 'realm' module is
disabled.
··· > On Tue, Oct 6, 2015 at 1:33 PM, Zbynek N <icema...@gmail.com > > wrote:
Issue is solved. I was try to run foreman-installer with my !UNCHANGED!
foreman-installer-answer.yml and proxy is running fine now.
Hard to say where the problem was.
Dne úterý 6. října 2015 15:49:30 UTC+2 Zbynek N napsal(a):
··· > > > > Dne úterý 6. října 2015 13:00:01 UTC+2 ohad napsal(a): >> >> >> >> On Tue, Oct 6, 2015 at 1:33 PM, Zbynek N wrote: >> >>> Hi guys, >>> >>> do you anyone know, where is problem when foreman-proxy after the >>> running about 5s is stopped? >>> Anyone met this issue? Foreman itself works fine. >>> >>> >> What's in the logs? >> >> Ohad >> >>> Thanks >>> >>> -- >>> You received this message because you are subscribed to the Google >>> Groups "Foreman users" group. >>> To unsubscribe from this group and stop receiving emails from it, send >>> an email to foreman-user...@googlegroups.com. >>> To post to this group, send email to forema...@googlegroups.com. >>> Visit this group at http://groups.google.com/group/foreman-users. >>> For more options, visit https://groups.google.com/d/optout. >>> >> > W, [2015-10-06T12:10:15.846830 #21055] WARN -- : Couldn't find settings > file /etc/foreman-proxy/settings.d/foreman_proxy.yml. Using default > settings. > I, [2015-10-06T12:10:15.847248 #21055] INFO -- : 'foreman_proxy' settings > were initialized with default values: :enabled: true > I, [2015-10-06T12:10:15.854295 #21055] INFO -- : 'facts' module is > disabled. > I, [2015-10-06T12:10:15.854739 #21055] INFO -- : 'dns' module is disabled. > I, [2015-10-06T12:10:15.855019 #21055] INFO -- : 'templates' module is > disabled. > I, [2015-10-06T12:10:15.855347 #21055] INFO -- : 'tftp' module is > disabled. > I, [2015-10-06T12:10:15.855682 #21055] INFO -- : 'dhcp' module is > disabled. > I, [2015-10-06T12:10:16.205257 #21055] INFO -- : 'puppet' settings were > initialized with default values: :puppetdir: /etc/puppet, > :salt_puppetrun_cmd: puppet.run, :use_cache: true > I, [2015-10-06T12:10:16.212976 #21055] INFO -- : 'bmc' module is disabled. > I, [2015-10-06T12:10:16.213511 #21055] INFO -- : 'realm' module is > disabled. > >
