I've been having the hardest time trying to figure out why some of my
puppet modules go into both my "staging" and "production" environment, and
yet some only go into "production". I only have one folder
(/etc/puppet/modules/*) and the foreman/master puppet.conf looks like:
File managed with puppet
Module: 'puppet'
[main]
# The Puppet log directory.
# The default value is '$vardir/log'.
logdir = /var/log/puppet
# Where Puppet PID files are kept.
# The default value is '$vardir/run'.
rundir = /var/run/puppet
# Where SSL certificates are kept.
# The default value is '$confdir/ssl'.
ssldir = $vardir/ssl
# Allow services in the 'puppet' group to access key (Foreman + proxy)
privatekeydir = $ssldir/private_keys { group = service }
hostprivkey = $privatekeydir/$certname.pem { mode = 640 }
# Puppet 3.0.x requires this in both [main] and [master] - harmless on
agents
autosign = $confdir/autosign.conf { mode = 664 }
show_diff = false
hiera_config = $confdir/hiera.yaml
Next part of the file is managed by a different template
Module: 'puppet'
[agent]
# The file in which puppetd stores a list of the classes
# associated with the retrieved configuration. Can be loaded in
# the separate puppet
executable using the --loadclasses
# option.
# The default value is '$statedir/classes.txt'.
classfile = $vardir/classes.txt
# Where puppetd caches the local configuration. An
# extension indicating the cache format is added automatically.
# The default value is '$confdir/localconfig'.
localconfig = $vardir/localconfig
# Disable the default schedules as they cause continual skipped
# resources to be displayed in Foreman - only for Puppet >= 3.4
default_schedules = false
report = true
pluginsync = true
masterport = 8140
listen = true
splay = false
splaylimit = 1800
runinterval = 1800
noop = false
configtimeout = 120
usecacheonfailure = true
Module: 'puppet'
[master]
reports = foreman
external_nodes = /etc/puppet/node.rb
node_terminus = exec
ca = true
strict_variables = false
always_cache_features = true
basemodulepath =
/etc/puppet/environments/common:/etc/puppet/modules:/usr/share/puppet/modules
