I have taken over a server running Foreman 2.5 on Ubuntu 20.04
Encountered only minor issues during the updates to 3.5
However after the update to Foreman 3.6 I receive a abort error during the foreman-rake db:migrate.
I’ve tried:
sudo gem update bundler
sudo gem update --system
My initial thinking is there is some issue with environment variables and I’m completely new to foreman. Any ideas to point me in the right direction would be awesome.
Expected same result as updates 3.0 - 3.5. I expected no errors
Foreman 3.6
Ubuntu 20.04
root@foreman:/tmp# foreman-rake db:migrate --trace
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
rake aborted!
NameError: uninitialized constant Setting::BLANK_ATTRS
/usr/share/foreman/vendor/ruby/2.7.0/gems/foreman_ansible-6.3.1/app/models/setting/ansible.rb:6:in <class:Ansible>' /usr/share/foreman/vendor/ruby/2.7.0/gems/foreman_ansible-6.3.1/app/models/setting/ansible.rb:5:in class:Setting’
/usr/share/foreman/vendor/ruby/2.7.0/gems/foreman_ansible-6.3.1/app/models/setting/ansible.rb:3:in <top (required)>' /usr/share/foreman/vendor/ruby/2.7.0/gems/polyglot-0.3.5/lib/polyglot.rb:65:in require’
/usr/share/foreman/vendor/ruby/2.7.0/gems/polyglot-0.3.5/lib/polyglot.rb:65:in require' /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/dependencies/interlock.rb:14:in block in loading’
/usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/concurrency/share_lock.rb:151:in exclusive' /usr/share/foreman/vendor/ruby/2.7.0/gems/activesupport-6.1.7.3/lib/active_support/dependencies/interlock.rb:13:in loading’
/usr/share/foreman/vendor/ruby/2.7.0/gems/foreman_ansible-6.3.1/lib/foreman_ansible/engine.rb:25:in block in <class:Engine>' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:32:in instance_exec’
/usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:32:in run' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:61:in block in run_initializers’
/usr/lib/ruby/2.7.0/tsort.rb:228:in block in tsort_each' /usr/lib/ruby/2.7.0/tsort.rb:350:in block (2 levels) in each_strongly_connected_component’
/usr/lib/ruby/2.7.0/tsort.rb:422:in block (2 levels) in each_strongly_connected_component_from' /usr/lib/ruby/2.7.0/tsort.rb:431:in each_strongly_connected_component_from’
/usr/lib/ruby/2.7.0/tsort.rb:421:in block in each_strongly_connected_component_from' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:50:in each’
/usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:50:in tsort_each_child' /usr/lib/ruby/2.7.0/tsort.rb:415:in call’
/usr/lib/ruby/2.7.0/tsort.rb:415:in each_strongly_connected_component_from' /usr/lib/ruby/2.7.0/tsort.rb:349:in block in each_strongly_connected_component’
/usr/lib/ruby/2.7.0/tsort.rb:347:in each' /usr/lib/ruby/2.7.0/tsort.rb:347:in call’
/usr/lib/ruby/2.7.0/tsort.rb:347:in each_strongly_connected_component' /usr/lib/ruby/2.7.0/tsort.rb:226:in tsort_each’
/usr/lib/ruby/2.7.0/tsort.rb:205:in tsort_each' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/initializable.rb:60:in run_initializers’
/usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/application.rb:391:in initialize!' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/railtie.rb:207:in public_send’
/usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/railtie.rb:207:in method_missing' /usr/share/foreman/config/environment.rb:5:in <top (required)>’
/usr/share/foreman/vendor/ruby/2.7.0/gems/polyglot-0.3.5/lib/polyglot.rb:65:in require' /usr/share/foreman/vendor/ruby/2.7.0/gems/polyglot-0.3.5/lib/polyglot.rb:65:in require’
/usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/application.rb:367:in require_environment!' /usr/share/foreman/vendor/ruby/2.7.0/gems/railties-6.1.7.3/lib/rails/application.rb:533:in block in run_tasks_blocks’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in block in execute' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in each’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in execute' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in block in invoke_with_call_chain’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in synchronize' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in invoke_with_call_chain’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:243:in block in invoke_prerequisites' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in each’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in invoke_prerequisites' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:218:in block in invoke_with_call_chain’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in invoke' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in invoke_task’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block (2 levels) in top_level' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in each’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in block in top_level' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in run_with_threads’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in top_level' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in block in run’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in standard_exception_handling' /usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in run’
/usr/share/foreman/vendor/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in <top (required)>' /usr/bin/rake:23:in load’
/usr/bin/rake:23:in `’
Tasks: TOP => db:migrate => db:load_config => environment
root@foreman:/tmp#
