> Hi all,
> I'm using the following version of foreman:
> foreman-console-0.5.1-1.el6.noarch
> foreman-proxy-0.5.1-1.el6.noarch
> foreman-sqlite-0.5.1-1.el6.noarch
> foreman-0.5.1-1.el6.noarch
> I'm trying to figure out what is the minimum information that I need to
> put into a curl post to add a host, I've tried the curl example but I get
> an error. I've also tried the following but I still get an error:
> curl -u admin:password -H "Accept:application/json" -d
> "host[name]=test08.uncommonsense.local" -d "host[environment_id]=3" -d
> "host[mac]=00:00:00:00:01" -d "host[ip]=10.0.2.26" -d
> "host[architecture_id]=2" -d "host[operatingsystem_id]=2" -d
> "host[ptable_id]=10" -d "host[build]=0" -d "host[subnet_id]=255.255.255.0"
> -d "host[puppetmaster_name=localhost"
subnet is an id, not a value,
also I'm not sure exactly when we changed it ( i think after 0.5.x), but
you should not use puppetmaster_name, rather puppetmaster_id or similar).
check your logs when creating a host via the ui, you could see the exact
names.
also, its recommended to update to 1.0
Ohad
On Tue, Jun 26, 2012 at 4:33 PM, Action Jack wrote:
http://localhost:8080/hosts
Am I doing something wrong or has the example changed?
Cheers
Action Jack
“Foreman users” group.
To view this discussion on the web visit
https://groups.google.com/d/msg/foreman-users/-/KhsR2eAAY50J.
>> Hi all,
>>> foreman-console-0.5.1-1.el6.**noarch
>>> foreman-proxy-0.5.1-1.el6.**noarch
>>> foreman-sqlite-0.5.1-1.el6.**noarch
>>> "host[name]=test08.**uncommonsense.local" -d "host[environment_id]=3"
>>> -d "host[mac]=00:00:00:00:01" -d "host[ip]=10.0.2.26" -d
>>> **0" -d "host[puppetmaster_name=**localhost"
>> names.
>> Ohad
>>> Cheers
>>> Action Jack
>>> Hi Ohad,
> I've updated to 1.0 and it does tell you what is missing from the input so
> now I put in:
> "host[name]=test09.uncommonsense.local" -d "host[environment_id]=3" -d
> "host[mac]=46:25:a5:51:b5:db" -d "host[ip]=10.0.2.27" -d
> "host[ptable_id]=10" -d "host[puppet_proxy_id]=1" http://localhost:8080
> /hosts
> Unfortunately I get the following error:
> Started POST "/hosts" for 10.0.2.2 at Sat Jun 23 09:43:37 +0000 2012
> Processing by HostsController#create as JSON
> Parameters: {"host"=>{"architecture_id"=>"2", "puppet_proxy_id"=>"1",
> "mac"=>"46:25:a5:51:b5:db", "ip"=>"10.0.2.27",
> "name"=>"test09.uncommonsense.local", "operatingsystem_id"=>"2",
> "ptable_id"=>"10"}}
> Authorized user admin(Admin User)
> Failed to save: Environment can't be blank
> Completed 422 Unprocessable Entity in 145ms (Views: 0.3ms | ActiveRecord:
> 3.6ms)
> Started POST "/hosts" for 10.0.2.2 at Sat Jun 23 09:43:52 +0000 2012
> "mac"=>"46:25:a5:51:b5:db", "ip"=>"10.0.2.27", "environment_id"=>"3",
> "ptable_id"=>"10"}}
> Add DNS A record for test09.uncommonsense.local/10.0.2.27
> Operation FAILED: undefined method `associated_type' for
> #<Audited::Adapters::ActiveRecord::Audit:0x7f846e475b90>
sadly this seems like the rake db:migrate didn't happen via rpm update,
please run it manually and try again
Ohad
On Tue, Jun 26, 2012 at 6:47 PM, Action Jack wrote:
Completed 500 Internal Server Error in 305ms
ArgumentError (There was no default layout for HostsController in
[#<ActionView::FileSystemResolver:0x7f846ffa2b20 @caching=true,
@path=“/usr/share/foreman/app/views”,
@cached={#<ActionView::LookupContext::DetailsKey:0x7f846e05bf00
@hash=70103379140480>=>{“audits”=>{“index”=>{false=>[app/views/audits/index.html.erb]},
“row”=>{true=>[app/views/audits/_row.erb]}},
“layouts”=>{“audits”=>{false=>}, “statistics”=>{false=>},
“users”=>{false=>}, “dashboard”=>{false=>},
“application”=>{false=>[app/views/layouts/application.html.erb]},
“hosts”=>{false=>}},
“statistics”=>{“index”=>{false=>[app/views/statistics/index.html.erb]}},
“common”=>{“searchbar”=>{true=>[app/views/common/_searchbar.erb]}},
“bookmarks”=>{“list”=>{true=>[app/views/bookmarks/_list.html.erb]}},
“users”=>{“login”=>{false=>[app/views/users/login.html.erb]}},
“dashboard”=>{“index”=>{false=>[app/views/dashboard/index.html.erb]}},
“hosts”=>{“index”=>{false=>[app/views/hosts/index.html.erb]},
“list”=>{true=>[app/views/hosts/_list.html.erb]}},
“home”=>{“topbar”=>{true=>[app/views/home/_topbar.rhtml]},
“user_dropdown”=>{true=>[app/views/home/_user_dropdown.rhtml]},
“settings”=>{true=>[app/views/home/_settings.html.erb]}}},
#<ActionView::LookupContext::DetailsKey:0x7f846e4d9668
@hash=70103381494580>=>{“layouts/action_controller”=>{“base”=>{false=>}},
“layouts”=>{“application”=>{false=>}, “hosts”=>{false=>}}},
#<ActionView::LookupContext::DetailsKey:0x7f846e07d088
@hash=70103379208260>=>{“layouts”=>{“fact_values”=>{false=>},
“reports”=>{false=>}},
“fact_values”=>{“welcome”=>{false=>[app/views/fact_values/welcome.html.erb]}},
“reports”=>{“welcome”=>{false=>[app/views/reports/welcome.html.erb]}}}}>]):
app/controllers/application_controller.rb:278:in `generic_exception’
BTW: I’m using a Foreman DNS smart proxy
Cheers
-Martin
https://groups.google.com/d/msg/foreman-users/-/3W4dVb9UZEQJ.
Yes that has fixed it, Thanks Ohad!
-Martin
>>> Hi all,
>>> names.
>>> also, its recommended to update to 1.0 :)
>>> Ohad
>>>> Cheers
>>>> Action Jack
>>>> Hi Ohad,
>> so now I put in:
>> /hosts
>> "ptable_id"=>"10"}}
>> 3.6ms)
>> "ptable_id"=>"10"}}
> please run it manually and try again :)
> Ohad
>> [#> @path="/usr/share/foreman/app/views",
>> @cached={#> @hash=70103379140480>=>{"audits"=>{"index"=>{false=>[app/views/audits/index.html.erb]},
>> "row"=>{true=>[app/views/audits/_row.erb]}},
>> "layouts"=>{"audits"=>{false=>[]}, "statistics"=>{false=>[]},
>> "users"=>{false=>[]}, "dashboard"=>{false=>[]},
>> "application"=>{false=>[app/views/layouts/application.html.erb]},
>> "hosts"=>{false=>[]}},
>> "statistics"=>{"index"=>{false=>[app/views/statistics/index.html.erb]}},
>> "common"=>{"searchbar"=>{true=>[app/views/common/_searchbar.erb]}},
>> "bookmarks"=>{"list"=>{true=>[app/views/bookmarks/_list.html.erb]}},
>> "users"=>{"login"=>{false=>[app/views/users/login.html.erb]}},
>> "dashboard"=>{"index"=>{false=>[app/views/dashboard/index.html.erb]}},
>> "hosts"=>{"index"=>{false=>[app/views/hosts/index.html.erb]},
>> "list"=>{true=>[app/views/hosts/_list.html.erb]}},
>> "home"=>{"topbar"=>{true=>[app/views/home/_topbar.rhtml]},
>> "user_dropdown"=>{true=>[app/views/home/_user_dropdown.rhtml]},
>> "settings"=>{true=>[app/views/home/_settings.html.erb]}}},
>> #> @hash=70103381494580>=>{"layouts/action_controller"=>{"base"=>{false=>[]}},
>> "layouts"=>{"application"=>{false=>[]}, "hosts"=>{false=>[]}}},
>> #> @hash=70103379208260>=>{"layouts"=>{"fact_values"=>{false=>[]},
>> "reports"=>{false=>[]}},
>> "fact_values"=>{"welcome"=>{false=>[app/views/fact_values/welcome.html.erb]}},
>> "reports"=>{"welcome"=>{false=>[app/views/reports/welcome.html.erb]}}}}>]):
>> app/controllers/application_controller.rb:278:in `generic_exception'
>> BTW: I'm using a Foreman DNS smart proxy
>> Cheers
>> -Martin
>> "Foreman users" group.
>> To post to this group, send email to foreman-users@googlegroups.com.
