Foreman Schedule remote job legacy UI is not working correctly
Problem: I just updated to foreman 3.14 and during the testing I noticed that Schedule Remote job old style UI is not working as expected, fg. Ansible Commands/Run Command shows uri field instead of command field and other Job Templates do not show any input fields at all. The new UI seems to work. Is it the issue or the old UI is not supported anymore ?
Expected outcome: Schedule remote job UI works correctly
**Foreman and Proxy versions:**3.14
**Foreman and Proxy plugin versions:**3.14
**Distribution and version:**RHEL9
Could you attach some screenshots to demonstrate?
Ahoj Adame, sorry for false alarm, this did not work for me after upgrade but I tested it today and it seems to work now. I do not know what was the problem, I tried to clean browser cache, incognito browsing and nothing helped. Anyway it works now, thank you.
All good. While the old form is bound to go away eventually in favor of the new one, it should still continue working until that happens.
Out of curiosity, do you have a reason for using the old one or is it just a matter of habit?
It is more or less habit, the old form is a little bit faster to fill because all settings are on one page and there are minor things like Job Category is not searchable in new UI etc. Nothing crucial.
