I've a Foreman version 1.14.1 installed. I've a problem with update of
settings.
When I click and change a setting, there is a circle with waiting screen
and nothing happens, after reloading the page the settings is unchanged.
I've inspected what happens after changing a setting, and a javascript is
run and gets 403 after PUT as below:
Failed to load resource: the server responded with a status of 403
(Forbidden)
settings:1 Uncaught SyntaxError: Unexpected token < in JSON at position 0
at JSON.parse (<anonymous>)
at Function.le.parseJSON (bundle-9671b40e053a06666c68.js:31)
at HTMLSpanElement.error
(application-b2577d2c9b8a4aaa635f3281e3856ed513f80d8795cdcbc89ed0896c2ef1be8e.js:249)
at t.<anonymous>
(application-b2577d2c9b8a4aaa635f3281e3856ed513f80d8795cdcbc89ed0896c2ef1be8e.js:323)
at Object.r (bundle-9671b40e053a06666c68.js:19)
at c (bundle-9671b40e053a06666c68.js:29)
at Object.fireWith [as rejectWith] (bundle-9671b40e053a06666c68.js:29)
at n (bundle-9671b40e053a06666c68.js:31)
at XMLHttpRequest.t (bundle-9671b40e053a06666c68.js:31)
bundle-9671b40e053a06666c68.js:31 PUT
https://aaaa.aaaa.caaa.com/settings/email_reply_address 403 (Forbidden)
send @ bundle-9671b40e053a06666c68.js:31
ajax @ bundle-9671b40e053a06666c68.js:31
(anonymous) @
application-b2577d2c9b8a4aaa635f3281e3856ed513f80d8795cdcbc89ed0896c2ef1be8e.js:364
save @
e.saveWithUrlHook @
submit @
r @ bundle-9671b40e053a06666c68.js:19
dispatch @ bundle-9671b40e053a06666c68.js:30
v.handle @ bundle-9671b40e053a06666c68.js:29
at t.<anonymous>
le.parseJSON @ bundle-9671b40e053a06666c68.js:31
error @
(anonymous) @
c @ bundle-9671b40e053a06666c68.js:29
fireWith @ bundle-9671b40e053a06666c68.js:29
n @ bundle-9671b40e053a06666c68.js:31
t @ bundle-9671b40e053a06666c68.js:31
(anonymous) @
save @
e.saveWithUrlHook @
submit @
at t.<anonymous>
Settings.yaml file:
:unattended: true
:login: true
:require_ssl: true
:locations_enabled: false
:organizations_enabled: false
:puppetrun: false
:puppetssldir: /etc/puppetlabs/puppet/ssl
The following values are used for providing default settings during db
migrate
:oauth_active: true
:oauth_map_users: false
:oauth_consumer_key: AXtDGzUVaAircTfWRpFdTyoN22grGdEn
:oauth_consumer_secret: kN7wW7NADWSBRbgnaH55EhHcL476Rbj5
Websockets
:websockets_encrypt: on
Seems that PUT doesn't work, I've check to GET the settings is working.
Any idea how to solve this?
Best regards,
Pawel
