I inherited a foreman/katello installed and setup on CentOS Linux release 7.6.1810. I am unable to load any patches/updates and really have no idea how this works. I read several articles and procedures on installing, but nothing can be found for the beginner. Also, this instance contains repo’s from centos 6/7, redhat 6/7. I don’t even know how redhat repos got on there as mrepo is not installed(from what I read, they should be used?).
Get beginner documentation so I can make this work again.
N/A
katello-3.5.2
proxy 1.16.2
Foreman 1.16.2
System Status
System Status
Smart Proxies
Available Providers
Compute Resources
Plugins
Name Description Author Version
bastion Bastion provides a UI library of AngularJS based components designed to integrate and work with Foreman. Eric D Helms and Walden Raines 6.1.5
foreman-tasks The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks. Ivan Nečas 0.10.9
foreman_docker Provision and manage Docker containers and images from Foreman. Daniel Lobato, Amos Benari 3.2.1
foreman_virt_who_configure A plugin to make virt-who configuration easy Foreman virt-who-configure team 0.1.1
katello Content and Subscription Management plugin for Foreman N/A 3.5.2
logs
018-12-28 10:22:09 9492624d [app] [I] Parameters: {"root"=>{}}
2018-12-28 10:22:09 9492624d [app] [I] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.5.2/app/views/katello/api/v2/root/resource_
list.json.rabl within katello/api/v2/layouts/collection (2.6ms)
2018-12-28 10:22:09 9492624d [app] [I] Completed 200 OK in 18ms (Views: 4.1ms | ActiveRecord: 0.0ms)
2018-12-28 10:22:09 83a593f1 [app] [I] Started GET "/rhsm/consumers/c90d8d51-12f3-4c42-8a46-05f859fc94a9/certificates/serials" for 10.20.3.189 at 20
18-12-28 10:22:09 -0500
2018-12-28 10:22:09 83a593f1 [app] [I] Processing by Katello::Api::Rhsm::CandlepinProxiesController#serials as JSON
2018-12-28 10:22:09 83a593f1 [app] [I] Parameters: {"id"=>"c90d8d51-12f3-4c42-8a46-05f859fc94a9"}
2018-12-28 10:22:09 83a593f1 [app] [I] Completed 200 OK in 125ms (Views: 0.5ms | ActiveRecord: 2.6ms)
2018-12-28 10:22:09 02db0583 [app] [I] Started GET "/rhsm/status" for 10.20.3.189 at 2018-12-28 10:22:09 -0500
2018-12-28 10:22:09 02db0583 [app] [I] Processing by Katello::Api::Rhsm::CandlepinProxiesController#server_status as JSON
2018-12-28 10:22:09 02db0583 [app] [I] Completed 200 OK in 20ms (Views: 0.6ms | ActiveRecord: 0.0ms)
2018-12-28 10:22:09 4995e426 [app] [I] Started GET "/rhsm/consumers/c90d8d51-12f3-4c42-8a46-05f859fc94a9" for 10.20.3.189 at 2018-12-28 10:22:09 -05
00
2018-12-28 10:22:09 4995e426 [app] [I] Processing by Katello::Api::Rhsm::CandlepinProxiesController#consumer_show as JSON
2018-12-28 10:22:09 4995e426 [app] [I] Parameters: {"id"=>"c90d8d51-12f3-4c42-8a46-05f859fc94a9"}
2018-12-28 10:22:09 4995e426 [app] [I] Current user: c90d8d51-12f3-4c42-8a46-05f859fc94a9 (regular user)
2018-12-28 10:22:09 4995e426 [app] [I] Completed 200 OK in 129ms (Views: 15.7ms | ActiveRecord: 1.8ms)
2018-12-28 10:22:09 79466372 [app] [I] Started GET "/rhsm/consumers/c90d8d51-12f3-4c42-8a46-05f859fc94a9/content_overrides" for 10.20.3.189 at 2018-
2018-12-28 10:22:09 79466372 [app] [I] Processing by Katello::Api::Rhsm::CandlepinProxiesController#get as JSON
2018-12-28 10:22:09 79466372 [app] [I] Parameters: {"id"=>"c90d8d51-12f3-4c42-8a46-05f859fc94a9"}
2018-12-28 10:22:09 79466372 [app] [I] Current user: c90d8d51-12f3-4c42-8a46-05f859fc94a9 (regular user)
2018-12-28 10:22:09 79466372 [app] [I] Completed 200 OK in 39ms (Views: 0.4ms | ActiveRecord: 0.7ms)
2018-12-28 10:22:18 09126233 [app] [I] Started GET "/notification_recipients" for 172.19.72.23 at 2018-12-28 10:22:18 -0500
2018-12-28 10:22:18 09126233 [app] [I] Processing by NotificationRecipientsController#index as JSON
2018-12-28 10:22:18 09126233 [app] [I] Current user: mstone (administrator)
2018-12-28 10:22:18 09126233 [app] [I] Completed 200 OK in 5ms (Views: 0.2ms | ActiveRecord: 0.4ms)
