'foremanctl features' was working, then broke after deployment
I followed the 3.19 containerized deployment guide at Installing Foreman Server with Katello 4.21 plugin (containerized) on Enterprise Linux. After I initially installed foremanctl from dnf, the foremanctl features command worked… then I did a deployment (which worked) and after the deployment, the features command is broken with this error:
[root@foreman-02 ~]# foremanctl features
TASK [Print features] ************************************************************************************************************************************************************************
fatal: [localhost]: FAILED! =>
msg: |-
The task includes an option with an undefined variable. The error was: {{ (flavor_features + features) }}: ‘flavor_features’ is undefined. ‘flavor_features’ is undefined. {{ (flavor_features + features) }}: ‘flavor_features’ is undefined. ‘flavor_features’ is undefined
    The error appears to be in '/usr/share/foremanctl/src/playbooks/features/features.yaml': line 14, column 7, but may
    be elsewhere in the file depending on the exact syntax problem.
    The offending line appears to be:
      tasks:
        - name: Print features
          ^ here
foremanctl features would continue to work after deployment (or whatever I may have done to break it).
[root@foreman-02 ~]# podman images
REPOSITORY                        TAG           IMAGE ID      CREATED        SIZE
quay.io/sclorg/postgresql-13-c9s  latest        2c7f99d16e3e  6 days ago     379 MB
quay.io/foreman/foreman           3.19          9c73f94dd101  2 weeks ago    998 MB
quay.io/foreman/candlepin         foreman-3.19  a26764a04788  2 weeks ago    634 MB
quay.io/foreman/pulp              foreman-3.19  1c486fcabfb0  2 weeks ago    650 MB
quay.io/sclorg/redis-6-c9s        latest        c7ac11061bbe  17 months ago  280 MB
I figured out what I did that broke it.
I was trying to figure out what --flavor was as a flag, so I passed:
foremanctl deploy --flavor taco
…expecting “taco is not a flavor, try blah blah blah” … but there was no error-checking like that and THAT is what broke it. (at step TASK [Include iop databases] if anyone cares)
I just ran:
foremanctl deploy --flavor katello
and after the ansible run, now it works again:
FEATURE                   STATE        DESCRIPTION
foreman                   enabled      Base Foreman Server
hammer                    enabled      Foreman CLI
katello                   enabled      Content and Subscription Management plugin for Foreman
foreman-proxy             available    Base Foreman Proxy
google                    available    Google Compute Engine plugin for Foreman
azure-rm                  available    Azure Resource Manager plugin for Foreman
remote-execution          available    Remote Execution plugin for Foreman
rh-cloud                  available    Connection to Red Hat Cloud
iop                       available    iop services
bmc                       available    Power management for bare metal hosts (IPMI, Redfish)
I’d love to know where my variable of ‘flavor’ got saved if anyone reading this knows. Hopefully this helps someone else.
Answering my own question about where it’s “remembering” the flavor from. Here’s how I got the answer:
[root@foreman-02 ~]# which foremanctl
/usr/bin/foremanctl
[root@foreman-02 ~]# cat /usr/bin/foremanctl | grep ^OBSAH_STATE
OBSAH_STATE=/var/lib/foremanctl
[root@foreman-02 ~]# cat /var/lib/foremanctl/parameters.yaml
features:
- hammer
flavor: katello
foreman_initial_admin_password: changeme
foreman_initial_admin_username: admin
foreman_initial_location: MyCity
foreman_initial_organization: MyOrg
Thanks for catching this!
We’ve implemented a stricter validation of possible flavor values in Set choices for flavor, so users can't select a wrong one by evgeni · Pull Request #559 · theforeman/foremanctl · GitHub
