Forklift and networking
Is anyone connecting to their vagrant VMs directly from another machine,
one other than the box running vagrant? I have a desktop I am using to spin
up vagrant VMs but I do most of my work on my laptop.
Currently, I am using bridged networking on the hypervisor to give the VM a
network IP that I can access directly. However, provisioning from my dev
environment doesn’t seem to work and some of the playbooks in forklift that
involve one VM connecting to another don’t seem to work either.
I know I could also forward ports using my desktop’s firewall but having to
add those rules every time I spin up a VM doesn’t seem ideal. Are there any
other options I am missing?
Thanks.
David
David,
Not sure if this will work in your exact situation, but many of us use this
script [1] to set up proxies with internal IP addresses. So if your VM had
an IP of 192.168.121.12 you would go to <hypervisor_hostname>:50012 and you
can access your VM. I am not sure if this can be tweaked for bridged
networking, but figured I would share.
[1] proxy generate virt hosts apache · GitHub
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
a network IP that I can access directly. However, provisioning from my dev
to add those rules every time I spin up a VM doesn’t seem ideal. Are there
any other options I am missing?
Thanks.
David
“foreman-dev” group.
