Hey guys!
First time around here… My name is Thiago, I'm working with Puppet for
about two years, now, I would like to try TheForeman.
So, I installed a brand new Ubuntu 14.04.1 - 64-Bit, to install TheForeman
on it. I'm following this
doc: Foreman :: Manual
But then, it failed:
root@theforeman-1:~# foreman-installer
Cannot create /var/lib/postgresql/9.3/main; parent directory
/var/lib/postgresql/9.3 does not exist
/Stage[main]/Postgresql::Server::Initdb/File[/var/lib/postgresql/9.3/main]/ensure:
change from absent to directory failed: Cannot create
/var/lib/postgresql/9.3/main; parent directory /var/lib/postgresql/9.3 does
not exist
/Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]:
Failed to call refresh: /usr/sbin/foreman-rake db:migrate returned 1
instead of one of [0]
/usr/sbin/foreman-rake db:migrate returned 1 instead of one of [0]
/Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]:
Failed to call refresh: /usr/sbin/foreman-rake db:seed returned 1 instead
of one of [0]
/usr/sbin/foreman-rake db:seed returned 1 instead of one of [0]
/Stage[main]/Foreman::Database/Foreman::Rake[apipie:cache]/Exec[foreman-rake-apipie:cache]:
Failed to call refresh: /usr/sbin/foreman-rake apipie:cache returned 1
/usr/sbin/foreman-rake apipie:cache returned 1 instead of one of [0]
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[theforeman-1.cpd.mydomain.com.br]:
Failed to call refresh: Could not load data from
https://theforeman-1.cpd.mydomain.com.br
Could not load data from https://theforeman-1.cpd.mydomain.com.br
Installing Done
[100%]
* Foreman is running at https://theforeman-1.cpd.mydomain.com.br
Initial credentials are admin / DjJ7ybZ2FbZLcKqg
* Foreman Proxy is running at
https://theforeman-1.cpd.mydomain.com.br:8443
* Puppetmaster is running at port 8140
The full log is at /var/log/foreman-installer/foreman-installer.log
Any tips?!
Thanks in advance!
Cheers!
Thiago
Hello again!
Is there anything I can do to install the stable version of TheForeman on
Trusty?!
I'm following the documentations but it does not even install.
What am I missing?!
Tks!
Thiago
On Tuesday, November 4, 2014 7:14:21 PM UTC-2, Thiago Martins wrote:
> Hey guys!
> First time around here... My name is Thiago, I'm working with Puppet for
> on it. I'm following this doc:
> http://theforeman.org/manuals/1.6/index.html#3.2ForemanInstaller
> not exist
> of one of [0]
> theforeman-1.cpd.mydomain.com.br]: Failed to call refresh: Could not load
> theforeman-1.cpd.mydomain.com.br]: Could not load data from
> Installing Done
> [100%]
> Any tips?!
> Thanks in advance!
> Cheers!
> Thiago
That's very odd - we regularly run automated tests of
foreman-installer on trusty (eg. [1]) and it shows no issues, so that
implies something is different about your environment. Your output
shows it had an issue with PostgreSQL - is it installed and running
after the installer exits?
Greg
[1] http://ci.theforeman.org/job/systest_foreman/4345/
On 6 November 2014 23:21, Thiago Martins wrote:
> Hello again! :-)
> Trusty?!
