I’m installing Foreman with foreman installer, using a YAML scenario. II’d like to also have a Smart Proxy on the same machine. The first run of the installer run gives an error as when it tries to register the proxy, doesn’t have valid credentials. So I have to copy the values from ‘/etc/foreman/settings.yaml’ and run again the installer.
foreman:
# oauth_consumer_key: # How can I set it in advance?
# oauth_consumer_secret:
foreman_proxy:
oauth_consumer_key: {copied-from-settings.yaml} # Set after a first installer run
oauth_consumer_secret: {copied-from-settings.yaml}
Install both foreman and foreman-proxy in a single installer run, installer is able to register DHCP
- foreman-3.9.1-1.el8.noarch
- foreman-proxy-3.9.1-1.el8.noarch
N.A.
AlmaLinux 8.9
The installer then fails with error Proxy my-server-example.com has failed to load one or more features (DHCP), check /var/log/foreman-proxy/proxy.log for configuration errors but the /var/log/foreman-proxy/proxy.log file does not exist…
