Want to set DHCP reservation using DHCP Smart Proxy REST Call
Example rest call:
curl -X POST https://foreman-smartproxy.example.com:8443/dhcp/192.168.1.0 --header ‘Content-Type: application/json’ -d ‘{“ip”:192.168.1.123,“mac”:00:11:22:11:22:33,“hostname”:test-dhcp-restapi.example.com}’
HTTP 200 (I guess) and the IP to be reserved on dhcp server e.g. in file /var/lib/dhcpd/dhcpd.leases:
host test-dhcp-restapi.example.com {
dynamic;
hardware ethernet 00:11:22:11:22:33;
fixed-address 192.168.1.123;
According to logs (below) it fails during ip address validation:
/usr/share/foreman-proxy/lib/proxy/validations.rb:17:in `validate_ip’
I checked the relevant code that validates the ip address
16 def validate_ip ip
17 raise Error, "Invalid IP Address #{ip}" unless ip =~ /(\d{1,3}\.){3}\d{1,3}/
18 ip
19 end
and I made sure, that the IP I used validates ok like this:
ruby -e ‘puts “invalid” unless “192.168.1.123” =~ /(\d{1,3}.){3}\d{1,3}/’
Since the IP isnt logged (see log below) it means, that IP is somehow lost during the request.
both: 1.19.1
just enabled dhcp module by:
:enabled: https
:use_provider: dhcp_isc
/var/log/foreman-proxy/proxy.log:
E, [2019-06-25T11:23:25.769498 ] ERROR -- : Invalid IP Address
D, [2019-06-25T11:23:25.769600 ] DEBUG -- : Invalid IP Address (Proxy::Validations::Error)
/usr/share/foreman-proxy/lib/proxy/validations.rb:17:in `validate_ip'
/usr/share/foreman-proxy/modules/dhcp_common/server.rb:132:in `add_record'
/usr/share/foreman-proxy/modules/dhcp_common/isc/omapi_provider.rb:29:in `add_record'
/usr/share/foreman-proxy/modules/dhcp/dhcp_api.rb:98:in `block in <class:DhcpApi>'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1611:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1611:in `block in compile!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `[]'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `block (3 levels) in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:994:in `route_eval'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:975:in `block (2 levels) in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1015:in `block in process_route'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1013:in `catch'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1013:in `process_route'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:973:in `block in route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:972:in `each'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:972:in `route!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1085:in `block in dispatch!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `block in invoke'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `catch'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1067:in `invoke'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1082:in `dispatch!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:907:in `block in call!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:907:in `call!'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:895:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/commonlogger.rb:33:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:219:in `call'
/usr/share/foreman-proxy/lib/proxy/log.rb:109:in `call'
/usr/share/foreman-proxy/lib/proxy/request_id_middleware.rb:9:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/xss_header.rb:18:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/path_traversal.rb:16:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/json_csrf.rb:18:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/base.rb:49:in `call'
/usr/share/gems/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/nulllogger.rb:9:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/show_exceptions.rb:25:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:182:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:2013:in `call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1487:in `block in call'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1787:in `synchronize'
/usr/share/gems/gems/sinatra-1.4.8/lib/sinatra/base.rb:1487:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/usr/share/gems/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/builder.rb:153:in `call'
/usr/share/gems/gems/rack-1.6.4/lib/rack/handler/webrick.rb:88:in `service'
/usr/share/ruby/webrick/httpserver.rb:138:in `service'
/usr/share/ruby/webrick/httpserver.rb:94:in `run'
/usr/share/ruby/webrick/server.rb:295:in `block in start_thread'
