[INFO][worker-0] gofer.messaging.adapter.proton.connection:87 - open: URL: amqps://foreman.example.com:5647| SSL: ca: /etc/rhsm/ca/katello-default-ca.pem|key: None|certificate: /etc/pki/consumer/bundle.pem|host-validation: None
[ERROR][worker-0] gofer.messaging.adapter.connect:33 - connect: proton+amqps://foreman.example.com:5647, failed: Connection amqps://foreman.itcbd.com:5647 disconnected: Condition('amqp:connection amqps://foreman.example.com:5647 disconnected: Condition('amqp:connection:framing-error', 'SSL Failure: error:1408F10B:SSL routines:ssl3_get_record:wrong
Then I checked foreman server and found 5647 is not up, after found that this port is depend on qpid-dispatch-router
rpm package. So after installing that package its running on 8672
& 5672
port. Though from config file /etc/qpid-dispatch/qdrouterd.conf
, changed port 8672 to 5647
but till now not working.
#Foreman Server:
CentOS Linux release 8.5.2111
foreman-3.0.1-1.el8.noarch
katello-4.2.1-1.el8.noarch
qpid-dispatch-router-1.14.0-1.el8.x86_64
qpid-dispatch-tools-1.14.0-1.el8.noarch
