A week ago I upgraded from 2.1 to 2.2.1 and although everything seemed
ok, I didn't have time to check everything. Yesterday, I noticed the
sync task was not running and I am unable to run any task now.
Checking various logs, I can see gutterball and candelpin are giving
connection erros to QPID (longer log excerpt at the bottom):
2015-06-15 13:45:12,289 [gutterball-qpid-connect] ERROR
org.candlepin.gutterball.receiver.EventReceiver - Unable to
initialize connection to QPID.
java.lang.RuntimeException: javax.jms.JMSException:*Error creating
connection: Keystore was tampered with, or password was incorrect*
2015-06-16 10:02:30,946 [=, org=] ERROR
org.candlepin.guice.AMQPBusPubProvider - Unable to instantiate
AMQPBusProvider:
javax.jms.JMSException: Error creating connection: Connection refused
Then I checked the installer log and I can see errors with the certificates:
[DEBUG 2015-06-10 16:37:05 main] Exec[[import client certificate
into gutterball keystore] signal import if pair has not been
imported](provider=posix): Executing check 'keytool -list -keystore
/etc/gutterball/certs/amqp//gutterball.jks -storepass
eS8hZrxxf6tcZfHEHkN2hYY2BXN9NnXc -alias gutterball'
[DEBUG 2015-06-10 16:37:05 main] Executing 'keytool -list -keystore
/Stage[main]/Certs::Gutterball/Certs::Ssltools::Keytool::Import_keypair[import
client certificate into gutterball keystore]/Exec[[import client
certificate into gutterball keystore] signal import if pair has not
been imported]/unless: keytool error: java.io.IOException: Keystore
imported](provider=posix): Executing 'echo importing keypair'
[DEBUG 2015-06-10 16:37:05 main] Executing 'echo importing keypair'
[DEBUG 2015-06-10 16:37:07 main] Exec[import client certificate
into Candlepin keystore](provider=posix): Executing check 'keytool
-list -keystore /etc/candlepin/certs/amqp/candlepin.jks -storepass
gttJyejWhbMVgcBkVwqsX6g9nSAb76WN -alias katello-default-ca'
[DEBUG 2015-06-10 16:37:07 main] Executing 'keytool -list -keystore
/Stage[main]/Certs::Candlepin/Exec[import client certificate into
Candlepin keystore]/unless: keytool error: java.lang.Exception:
Alias <katello-default-ca> does not exist
into Candlepin keystore](provider=posix): Executing 'openssl pkcs12
-export -name amqp-client -in /etc/pki/katello/certs/java-client.crt
-inkey /etc/pki/katello/private/java-client.key -out
/tmp/keystore.p12 -passout
file:/etc/pki/katello/keystore_password-file && keytool
-importkeystore -destkeystore
/etc/candlepin/certs/amqp/candlepin.jks -srckeystore
/tmp/keystore.p12 -srcstoretype pkcs12 -alias amqp-client -storepass
gttJyejWhbMVgcBkVwqsX6g9nSAb76WN -srcstorepass
gttJyejWhbMVgcBkVwqsX6g9nSAb76WN -noprompt && rm /tmp/keystore.p12'
[DEBUG 2015-06-10 16:37:07 main] Executing 'openssl pkcs12 -export
-name amqp-client -in /etc/pki/katello/certs/java-client.crt -inkey
/etc/pki/katello/private/java-client.key -out /tmp/keystore.p12
-passout file:/etc/pki/katello/keystore_password-file && keytool
[ WARN 2015-06-10 16:37:08 main]
Candlepin keystore]/returns: executed successfully
When I try it manually, I also get an error:
keytool -list -keystore /etc/candlepin/certs/amqp/candlepin.jks
-storepass ********* -alias katello-default-ca
keytool error: java.lang.Exception: Alias <katello-default-ca> does
not exist
Anything I can try to fix this? Any idea on how this could have happened?
From the logs:
/var/log/gutterball/gutterball.log
2015-06-15 13:42:42,223 [main] WARN
org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator
- HHH000208: org.hibernate.connection.C3P0ConnectionProvider has
been deprecated in favor of
org.hibernate.service.jdbc.connections.internal.C3P0ConnectionProvider;
that provider will be used instead.
2015-06-15 13:42:42,304 [main] WARN
com.mchange.v2.c3p0.management.ActiveManagementCoordinator - A
C3P0Registry mbean is already registered. This probably means that
an application using c3p0 was undeployed, but not all
PooledDataSources were closed prior to undeployment. This may lead
to resource leaks over time. Please take care to close all
PooledDataSources.
2015-06-15 13:42:43,022 [main] WARN
org.hibernate.id.UUIDHexGenerator - HHH000409: Using
org.hibernate.id.UUIDHexGenerator which does not generate IETF RFC
4122 compliant UUID values; consider using
org.hibernate.id.UUIDGenerator instead
at
org.candlepin.gutterball.receiver.EventReceiver$QpidConnectionThread.run(EventReceiver.java:179)
~[EventReceiver$QpidConnectionThread.class:na]
javax.jms.JMSException: Error creating connection: Keystore was
at
org.apache.qpid.client.AMQConnectionFactory.createConnection(AMQConnectionFactory.java:128)
~[qpid-client-0.30.jar:0.30]
at
org.candlepin.gutterball.receiver.EventReceiver.init(EventReceiver.java:82)
~[EventReceiver.class:na]
at
org.candlepin.gutterball.receiver.EventReceiver$QpidConnectionThread.run(EventReceiver.java:176)
Caused by: org.apache.qpid.AMQConnectionFailureException: Keystore
at
org.apache.qpid.client.AMQConnection.<init>(AMQConnection.java:503)
at
org.apache.qpid.client.AMQConnectionFactory.createConnection(AMQConnectionFactory.java:124)
... 2 common frames omitted
Caused by: org.apache.qpid.transport.TransportException: Error
creating SSL Context
at
org.apache.qpid.transport.network.security.SecurityLayerFactory$SSLSecurityLayer.<init>(SecurityLayerFactory.java:91)
~[qpid-common-0.30.jar:0.30]
at
org.apache.qpid.transport.network.security.SecurityLayerFactory.newInstance(SecurityLayerFactory.java:51)
at
org.apache.qpid.transport.Connection.connect(Connection.java:232)
at
org.apache.qpid.client.AMQConnectionDelegate_0_10.makeBrokerConnection(AMQConnectionDelegate_0_10.java:221)
at
org.apache.qpid.client.AMQConnection.makeBrokerConnection(AMQConnection.java:647)
at
org.apache.qpid.client.AMQConnection.<init>(AMQConnection.java:429)
... 3 common frames omitted
Caused by: java.io.IOException: Keystore was tampered with, or
at
sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:772)
~[na:1.7.0_79]
at
sun.security.provider.JavaKeyStore$JKS.engineLoad(JavaKeyStore.java:55)
~[na:1.7.0_79]
at java.security.KeyStore.load(KeyStore.java:1214) ~[na:1.7.0_79]
at
org.apache.qpid.transport.network.security.ssl.SSLUtil.getInitializedKeyStore(SSLUtil.java:172)
at
org.apache.qpid.ssl.SSLContextFactory.buildContext(SSLContextFactory.java:92)
at
org.apache.qpid.ssl.SSLContextFactory.buildClientContext(SSLContextFactory.java:62)
at
org.apache.qpid.transport.network.security.SecurityLayerFactory$SSLSecurityLayer.<init>(SecurityLayerFactory.java:78)
... 8 common frames omitted
Caused by: java.security.UnrecoverableKeyException: Password
verification failed
at
sun.security.provider.JavaKeyStore.engineLoad(JavaKeyStore.java:770)
~[na:1.7.0_79]
... 14 common frames omitted
2015-06-16 09:59:49,416 [main] INFO
org.candlepin.gutterball.servlet.GutterballContextListener -
Destroying gutterball context
org.candlepin.gutterball.receiver.EventReceiver - Closing QPID
connection
/var/log/candlepin/error.log
AMQPBusProvider:
at
at
org.candlepin.guice.AMQPBusPubProvider.<init>(AMQPBusPubProvider.java:81)
~[AMQPBusPubProvider.class:na]
at
org.candlepin.guice.AMQPBusPubProvider$$FastClassByGuice$$ef75a35a.newInstance(<generated>)
[guice-3.0.jar:na]
at
com.google.inject.internal.cglib.reflect.$FastConstructor.newInstance(FastConstructor.java:40)
[guice-3.0.jar:na]
at
com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:60)
[guice-3.0.jar:na]
at
com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
[guice-3.0.jar:na]
at
com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
[guice-3.0.jar:na]
at
com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:53)
[guice-3.0.jar:na]
at
com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
[guice-3.0.jar:na]
at
com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
[guice-3.0.jar:na]
at
com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
[guice-3.0.jar:na]
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
[guice-3.0.jar:na]
at
com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
[guice-3.0.jar:na]
at
com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
[guice-3.0.jar:na]
at com.google.inject.Guice.createInjector(Guice.java:95)
[guice-3.0.jar:na]
at
org.candlepin.guice.CandlepinContextListener.getInjector(CandlepinContextListener.java:146)
[CandlepinContextListener.class:na]
at
org.candlepin.guice.CandlepinGuiceResteasyBootstrap.contextInitialized(CandlepinGuiceResteasyBootstrap.java:57)
[CandlepinGuiceResteasyBootstrap.class:na]
at
org.candlepin.guice.CandlepinContextListener.contextInitialized(CandlepinContextListener.java:114)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4210)
[catalina-6.0.24.jar:na]
at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4709)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526) [catalina-6.0.24.jar:na]
at
org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
at
org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1277)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:321)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) [catalina-6.0.24.jar:na]
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:722)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045) [catalina-6.0.24.jar:na]
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at
org.apache.catalina.core.StandardService.start(StandardService.java:516)
at
org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:593)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
~[na:1.7.0_79]
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
~[na:1.7.0_79]
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
~[na:1.7.0_79]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_79]
at
org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
[bootstrap-6.0.24.jar:na]
at
org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: org.apache.qpid.AMQConnectionFailureException: Connection
refused
at
at
... 46 common frames omitted
connecting to broker
at
org.apache.qpid.transport.network.io.IoNetworkTransport.connect(IoNetworkTransport.java:89)
at
org.apache.qpid.transport.Connection.connect(Connection.java:243)
at
at
at
... 47 common frames omitted
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
~[na:1.7.0_79]
at
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
~[na:1.7.0_79]
at
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
~[na:1.7.0_79]
at
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
~[na:1.7.0_79]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
~[na:1.7.0_79]
at java.net.Socket.connect(Socket.java:579) ~[na:1.7.0_79]
at
org.apache.qpid.transport.network.io.IoNetworkTransport.connect(IoNetworkTransport.java:85)
... 51 common frames omitted
2015-06-16 10:02:34,595 [=, org=] WARN
2015-06-16 10:02:36,405 [=, org=] ERROR
org.candlepin.guice.CandlepinGuiceResteasyBootstrap - Could not
create Guice injector.
com.google.inject.CreationException: Guice creation errors:
1) Error injecting constructor, java.lang.RuntimeException:
