Hammer and API calls for importing puppet classes
Hi all,
I am working on some scripts for automating the deployment/import of our
puppet modules for our CI pipeline.
I am currently looking into both the hammercli as well as making a call to
the api (depending on what application could be doing this).
From both avenues, I am unable to execute the import of puppet classes.
From hammercli:
hammer proxy import_classes --id=1
Started POST "/api/smart_proxies/1/import_puppetclasses" for X.X.X.X at
2014-01-01 21:47:39 -0500
Processing by Api::V1::HomeController#route_error as JSON
Parameters: {"dryrun"=>nil,
"other"=>"smart_proxies/1/import_puppetclasses", "home"=>{"dryrun"=>nil}}
Authorized user admin(Admin User)
Rendered api/v1/errors/route_error.json.rabl (0.4ms)
Completed 404 Not Found in 22ms (Views: 1.1ms | ActiveRecord: 12.2ms)
From API script:
curl -s -H "Accept:application/json" \
-k -u $USER:$PASS \
$FOREMAN_URL/smart_proxies/1/import_puppetclasses | prettify_json.rb
Same result as the call from hammercli (which would make sense since it is
the same POST :wink:
I have verified the that proxy id maps to 1 for my puppet server. From the
web interface, I can manually import just fine.
I have also noticed however, that running the following does not pick up
changes anymore even when they do exist:
/usr/sbin/foreman-rake puppet:import:puppet_classes[batch]
RAILS_ENV=production
Any insights would be appreciated!
Thanks!
Chuck
> Hi all,
> From hammercli:
> From API script:
> -k -u $USER:$PASS
> the web interface, I can manually import just fine.
which version of foreman are you running? afair, this was introduced only
in the 1.4x series, see Feature #3693: API v2 - accept GET json format of object in PUT/POST requests to add/remove has_many associations - Foreman
Ohad
··· On Thu, Jan 2, 2014 at 4:55 AM, wrote:
Thanks!
Chuck
“Foreman users” group.
