I'm just starting using hammer (0.0.9) for creating hosts on a Libvirt
provider, and I stumbled upon a couple of details regarding the keys to be
used in the --compute-attributes argument:
The doc (
https://github.com/theforeman/hammer-cli-foreman/blob/master/doc/host_create.md)
says that "start" is a boolean key, and the Success Story (
Bug #3297: CLI success story tracker - Hammer CLI - Foreman) has an example using it as
"start=true". But in my tests "start=true" did not automatically start the
host, I had to use "start=1" instead.
Should I file a issue about it? Or is it ok the way it is now, and should
the Success Story be fixed instead? (And maybe the doc updated, too)
The "memory" key is said to accept a string which represents the value
in bytes. But can it also be written as e.g. "2G", "768M" and so on, just
like the "capacity" key for the --volume option? If so, then maybe the
docs/help should be updated to reflect this. On the other hand, if this
kind of notation is not possible for this key, maybe I should file a
request issue ;).
Thanks.
Marco
Hi Marco,
thanks for your feedback!
> Hi,
> to be used in the --compute-attributes argument:
> 1. The doc
> (https://github.com/theforeman/hammer-cli-foreman/blob/master/doc/host_create.md)
> (Bug #3297: CLI success story tracker - Hammer CLI - Foreman) has an example using it
> as "start=true". But in my tests "start=true" did not automatically
> start the host, I had to use "start=1" instead.
> should the Success Story be fixed instead? (And maybe the doc updated,
> too)
Yes, please do, we should fix it one way or the other.
> 2. The "memory" key is said to accept a string which represents the
> value in bytes. But can it also be written as e.g. "2G", "768M" and so
> on, just like the "capacity" key for the --volume option? If so, then
> maybe the docs/help should be updated to reflect this. On the other
> hand, if this kind of notation is not possible for this key, maybe I
> should file a request issue ;).
The memory size really has to be specified in bytes. I must admit it is
awkward, so please file a feature request for this.
Thanks for helping us to improve hammer user experience,
Martin
On 11/28/2013 01:51 PM, zerozerounouno@gmail.com wrote:
Thanks.
Marco
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com.
