Hello
I'm using Foreman 1.13 and oVirt 4.0.4 and I have an oVirt template with 2
disks, both with data, from which I want to spin-up new VMs via Foreman.
If I create the VM from Foreman everything is correct, the 2 disks are the
ones set in the oVirt template. But if I try from hammer CLI like this:
$ hammer host create --hostgroup-id=13 --compute-resource="My oVirt
Resource" --provision-method="image" --image="MyImage" --name="test-01"
–compute-attributes="start=1" --operatingsystem-id=2
Then, the new VM has only the "base" disk. And if I try like this
–volume="size_gb=8,storage_domain=ba2bd397-9222-424d-aecc-eb652c0169d9,bootable=true"
–volume="size_gb=25,storage_domain=ba2bd397-9222-424d-aecc-eb652c0169d9,bootable=false"
Then 2 disks are created and attached but the second one (the 25GB disk) is
a brand new disk and not a copy of the disk attached to the original
template.
Is this an Hammer bug? Has anyone got this working?
Thanks in advance
