Wit the new code, do we need to go add in specific help text? Note below
that help text for commands is missing.
– bk
[bkearney@bkearney hammer-cli]$ bundle exec bin/hammer -u admin -p
changeme product
Usage:
hammer product [OPTIONS] SUBCOMMAND [ARG] …
Parameters:
SUBCOMMAND subcommand
[ARG] … subcommand arguments
Subcommands:
create
delete
info
list
remove_sync_plan Delete assignment sync plan and product.
set_sync_plan Assign sync plan to product.
update
Options:
-h, --help print help
(reverse-i-search)`do': su^C service postgresql start
changeme domain
Usage:
hammer domain [OPTIONS] SUBCOMMAND [ARG] …
Parameters:
Subcommands:
create
delete
delete-parameter Delete parameter for a domain.
info
list
set-parameter Create or update parameter for a domain.
update
Options:
