I am having a problem running hammer commands. Every hammer command gives the following error:
# hammer host list
Error: undefined method `connection_options' for HammerCLI::Apipie::Command:Class
Warning: An error occured while loading module hammer_cli_foreman
Error: No such sub-command 'host'
See: 'hammer --help'
From an earlier thread, I noticed that for debugging the gem list was requested. So here it goes:
# hammer -d log
[ INFO 2018-02-23 05:59:28 Init] Initialization of Hammer CLI (0.10.2) has started...
[DEBUG 2018-02-23 05:59:28 Init] Running at ruby 2.2.2-p95
[ INFO 2018-02-23 05:59:28 Init] Configuration from the file /etc/hammer/cli_config.yml has been loaded
[ INFO 2018-02-23 05:59:28 Init] Configuration from the file /etc/hammer/cli.modules.d/foreman.yml has been loaded
[ INFO 2018-02-23 05:59:28 Init] Configuration from the file /root/.hammer/cli.modules.d/foreman.yml has been loaded
[ERROR 2018-02-23 05:59:28 Exception] Error: undefined method `connection_options' for HammerCLI::Apipie::Command:Class
[ WARN 2018-02-23 05:59:28 HammerCLI::Output::Output] Required adapter '' was not found, using 'base' instead
NoMethodError (undefined method `connection_options' for HammerCLI::Apipie::Command:Class):
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/commands.rb:42:in `foreman_api_connection'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/commands.rb:47:in `foreman_api'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/commands.rb:56:in `foreman_resource!'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/commands.rb:476:in `associated_resource'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/associating_commands.rb:40:in `<class:AddHostgroupCommand>'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/associating_commands.rb:39:in `<module:Hostgroup>'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/associating_commands.rb:36:in `<module:AssociatingCommands>'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/associating_commands.rb:2:in `<module:HammerCLIForeman>'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman/associating_commands.rb:1:in `<top (required)>'
/opt/rh/rh-ruby22/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:54:in `require'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman.rb:27:in `<module:HammerCLIForeman>'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/lib/hammer_cli_foreman.rb:5:in `<top (required)>'
/opt/rh/rh-ruby22/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:128:in `require'
/opt/rh/rh-ruby22/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:128:in `rescue in require'
/opt/rh/rh-ruby22/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:39:in `require'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:78:in `require_module'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:57:in `load!'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:72:in `load'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:83:in `block in load_all'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:82:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/modules.rb:82:in `load_all'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/bin/hammer:134:in `<top (required)>'
/bin/hammer:23:in `load'
/bin/hammer:23:in `<main>'
[ERROR 2018-02-23 05:59:28 Modules] Error while loading module hammer_cli_foreman
[DEBUG 2018-02-23 05:59:28 Init] Using locale 'en'
[DEBUG 2018-02-23 05:59:28 Init] 'mo' files for locale domain 'hammer-cli' loaded from '/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/locale'
[DEBUG 2018-02-23 05:59:28 Init] 'mo' files for locale domain 'hammer-cli-foreman' loaded from '/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-0.8.0/locale'
[ INFO 2018-02-23 05:59:28 HammerCLI::MainCommand] Called with options: {"option_debug"=>true}
[ERROR 2018-02-23 05:59:28 Exception] Error: No such sub-command 'log'
Clamp::UsageError (No such sub-command 'log'):
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.0.0/lib/clamp/subcommand/execution.rb:28:in `find_subcommand_class'
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.0.0/lib/clamp/subcommand/execution.rb:17:in `instatiate_subcommand'
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.0.0/lib/clamp/subcommand/execution.rb:10:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:68:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/lib/hammer_cli/abstract.rb:29:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-0.10.2/bin/hammer:147:in `<top (required)>'
# gem list
*** LOCAL GEMS ***
addressable (2.4.0)
ansi (1.4.3)
apipie-bindings (0.0.13)
awesome_print (1.7.0, 1.0.2)
bigdecimal (1.2.0)
bolt (0.13.0)
builder (3.2.3)
bundler (1.7.8)
bundler_ext (0.3.0)
CFPropertyList (2.3.6)
clamp (1.0.0)
concurrent-ruby (1.0.0)
daemon_controller (1.1.2)
erubis (2.7.0)
facter (2.4.6)
facterdb (0.3.10)
fast_gettext (1.1.0, 0.9.2)
fastercsv (1.5.4)
ffi (1.9.10)
gettext (3.2.2)
gettext-setup (0.24)
gssapi (1.2.0, 1.1.2)
gyoku (1.3.1)
hashie (2.0.5)
hiera (3.3.1)
hiera-eyaml (2.1.0)
highline (1.6.21)
httpclient (2.8.3)
io-console (0.4.2)
jgrep (1.4.1)
json (1.7.7)
json_pure (1.8.6)
kafo (1.0.5)
kafo_parsers (0.1.5)
kafo_wizards (0.0.1)
little-plugger (1.1.3)
locale (2.1.2, 2.0.9)
logging (1.8.2)
mime-types (1.19)
minitar (0.6.1)
multi_json (1.10.1)
net-http-persistent (2.8)
net-scp (1.2.1)
net-ssh (4.2.0)
netrc (0.7.7)
nori (2.6.0)
oauth (0.4.7)
orchestrator_client (0.2.2)
powerbar (1.0.11)
psych (2.0.0)
puppet (4.10.1)
rack (1.6.4)
rack-protection (1.5.3)
rake (0.9.6)
rb-inotify (0.9.7)
rb-readline (0.5.1)
rdoc (4.0.0)
rest-client (1.6.7)
rkerberos (0.1.3)
rubyipmi (0.10.0)
rubyntlm (0.6.2)
rubyzip (1.2.1)
sinatra (1.3.5)
smart_proxy_dynflow (0.1.8)
smart_proxy_remote_execution_ssh (0.1.6)
stomp (1.3.2)
table_print (1.5.1)
terminal-table (1.8.0)
text (1.3.1)
thor (0.19.1)
tilt (1.3.7)
trollop (2.1.2)
unicode-display_width (1.3.0)
win32-dir (0.4.9)
win32-process (0.7.5)
win32-security (0.2.5)
win32-service (0.8.8)
winrm (2.2.3)
winrm-fs (1.1.1)
# foreman-rake plugin:list
Collecting plugin information
Foreman plugin: foreman-tasks, 0.9.6, Ivan NeÄŤas, The goal of this plugin is to unify the way of showing task statuses across the Foreman instance.
It defines Task model for keeping the information about the tasks and Lock for assigning the tasks
to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the
same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks.
Foreman plugin: foreman_remote_execution, 1.3.7, Foreman Remote Execution team, A plugin bringing remote execution to the Foreman, completing the config management functionality with remote management functionality.
Foreman plugin: foreman_setup, 5.0.0, Dominic Cleal, Plugin for Foreman that helps set up provisioning.
Hammer should run without any problem.
How can I gather foreman and proxy versions?
See above
Note that this is my production Puppet server. So I am not in a position to perform intrusive changes.
