while running hammer command getting below error message
“Warning: An error occured while loading module hammer_cli_foreman_remote_execution.”
also while trying to run “hammer job-invocation --help” system is not unable to find the job-invocation command.
it should provide job-invocation output
Foreman version : 2.0.3
Foreman Proxy Version : 2.0.3
CentOS 7 (7.9.2009)
below is the logs we have from hammer -d
“[ WARN 2022-05-23T09:15:16 HammerCLIForemanOpenscap::ScapContentProfile] Resource ‘scap_content_profiles’ does not exist in the API
[ INFO 2022-05-23T09:15:16 Modules] Extension module hammer_cli_foreman_openscap (0.1.12) loaded.
[ WARN 2022-05-23T09:15:16 HammerCLIForemanRemoteExecution::JobInvocation] Resource ‘job_invocations’ does not exist in the API
[ERROR 2022-05-23T09:15:16 Modules] Error while loading module hammer_cli_foreman_remote_execution.
[ERROR 2022-05-23T09:15:16 Modules] undefined method action' for nil:NilClass /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution/job_invocation.rb:7:in create_option_builder’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/abstract.rb:184:in option_builder' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/abstract.rb:191:in build_options’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman-2.4.0/lib/hammer_cli_foreman/commands.rb:133:in build_options' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution/job_invocation.rb:81:in class:InfoCommand’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution/job_invocation.rb:38:in <class:JobInvocation>' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution/job_invocation.rb:2:in module:HammerCLIForemanRemoteExecution’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution/job_invocation.rb:1:in <top (required)>' /opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in require’
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in require' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution.rb:7:in module:HammerCLIForemanRemoteExecution’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli_foreman_remote_execution-0.2.1/lib/hammer_cli_foreman_remote_execution.rb:5:in <top (required)>' /opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:135:in require’
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:135:in rescue in require' /opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:39:in require’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:75:in require_module' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:54:in load!’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:69:in load' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:80:in block in load_all’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:79:in each' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:79:in load_all’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/bin/hammer:134:in <top (required)>' /usr/bin/hammer:23:in load’
/usr/bin/hammer:23:in <main>' --- Caused by --- <LoadError> cannot load such file -- hammer_cli_foreman_remote_execution /opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in require’
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in require' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:75:in require_module’
/opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:54:in load!' /opt/theforeman/tfm/root/usr/share/gems/gems/hammer_cli-2.4.0/lib/hammer_cli/modules.rb:69:in load’
[ WARN 2022-05-23T09:15:16 HammerCLIForemanTemplates::ImportCommand] Resource ‘templates’ does not exist in the API
[ WARN 2022-05-23T09:15:16 HammerCLIForemanTemplates::ExportCommand] Resource ‘templates’ does not exist in the API
[ INFO 2022-05-23T09:15:16 Modules] Extension module hammer_cli_foreman_templates (0.2.0) loaded.
[DEBUG 2022-05-23T09:15:16 HammerCLIForeman::CommandExtensions::PuppetEnvironment] Added predefined options for HammerCLIForeman::SmartProxy::ImportPuppetClassesCommand:”
