Hello plugin maintainers,
if your plugin has a model that includes Taxonomix and also is being audited, you’ll need to make sure that audit definition is above the include Taxonomix
line. This change will be required for compatibility with Foreman 1.18. I scanned through all commonly used plugins and found only 3 affected plugins that needs change. I sent PR to all of them
- https://github.com/theforeman/foreman_openscap/pull/330
- https://github.com/theforeman/foreman_remote_execution/pull/333
- https://github.com/theforeman/foreman_virt_who_configure/pull/82
So if I haven’t missed something, no actions is needed. If your tests starts to fail with NoMethodError organization_ids_changed?, it’s likely caused by the upcoming change.
Marek
