> "total_hosts": 193,"bad_hosts": 3,"bad_hosts_enabled": 3,"active_hosts": 15,
> "active_hosts_ok": 15,"active_hosts_ok_enabled": 15,"ok_hosts": 165,"
> ok_hosts_enabled": 165,"out_of_sync_hosts": 8,"out_of_sync_hosts_enabled": 8
> ,"disabled_hosts": 0,"pending_hosts": 1,"pending_hosts_enabled": 1,"
> good_hosts": 180,"good_hosts_enabled": 180,"percentage": 85,"reports_missing
> ": 1
> By hitting the /api/dashboard endpoint I get the above information.
> I am unclear on the definitions for a few of these data points:
> 1. Ok hosts = good hosts - active hosts?
OK hosts = hosts with recent (sooner than the outofsync interval)
successful (no errors, no changes, no pending changes)
reports
> 2. Good hosts = total hosts - bad hosts - out of sync hosts - pending
> hosts - reports_missing?
Good hosts = OK hosts + active hosts OK (last report is recent, with changes)
> 3. Does reports_missing factor into any of the (other) counts or
> percentage?
Not sure I understand the question. reports_missing represents the
number of hosts that don't have a last report
I realize this whole data isn't easy to understand at all, we should
include some help. A link to the manual with info in the API
response might even be enough.
I've opened a ticket to keep track of this problem:
http://projects.theforeman.org/issues/14877
You can read more about Foreman host statuses at http://www.theforeman.org/manuals/1.11/#4.9.2Sub-statuses
Thanks!
On 04/27, Eric Rodriguez wrote:
Daniel Lobato Garcia
@dLobatog
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
