Hi All,
I'm afraid I'm a newbie to foreman, puppet and ruby but I have been tasked
with getting up to speed with writing foreman plugins.
I followed the foreman-vagrant guide
at: https://github.com/garystafford/foreman-vagrant which gave me 3 VMs:
theforeman.example.com
agent01.example.com
agent02.example.com
All are managed by foreman version 1.9.3 and running under CentOS 7.0.1406
with puppet version 3.8.7.
All seems to work well however when I cloned the foreman_plugin_template
https://github.com/theforeman/foreman_plugin_template
And tried to follow the instructions… I was stymied when I went to use
bundle to install my plugin:
[vagrant@theforeman foreman_my_plugin]$ bundle install
Fetching gem metadata from https://rubygems.org/…
Fetching additional metadata from https://rubygems.org/…
Resolving dependencies…
Installing rake 11.3.0
Installing concurrent-ruby 1.0.2
Installing i18n 0.7.0
Installing minitest 5.9.1
Installing thread_safe 0.3.5
Installing tzinfo 1.2.2
Gem::InstallError: activesupport requires Ruby version >= 2.2.2.
An error occurred while installing activesupport (5.0.0.1), and Bundler
cannot continue.
Make sure that gem install activesupport -v '5.0.0.1'
succeeds before
bundling.
[vagrant@theforeman foreman_my_plugin]$ ruby -v
ruby 2.0.0p598 (2014-11-13) [x86_64-linux]
Any thoughts?
I did try installing the latest ruby but that just broke my foreman
installation so I reloaded my vagrant images from scratch.
Cheers,
Doug
> Hi All,
> tasked with getting up to speed with writing foreman plugins.
> agent01.example.com
> agent02.example.com
> 7.0.1406 with puppet version 3.8.7.
Foreman 1.9.3 is very old. The current stable version is 1.13.1, and the
development series is 1.14.
This repo isn't part of our documentation, I would recommend using a
development installation by following Foreman :: Contribute
> from:
Please note that plugins should only be installed on development
copies of Foreman. If Foreman is installed through packages, it isn't
suitable for developing on.
> Bundler cannot continue.
succeeds
> before bundling.
Run bundle install
in your Foreman directory after adding the plugin
to bundler.d/Gemfile.local.rb, not in the plugin. Again, this will only
work properly on a git checkout of Foreman, it shouldn't be attempted on
a package installation.
On 29/10/16 08:50, Doug Scoular wrote:
Dominic Cleal
dominic@cleal.org
