Hi All,
Apologies if this question has been asked before, but I can't find anything
definitive. I'm running Foreman 1.14.2 with Katello 3.3 with FreeIPA 4.4.
I've followed the realm integration instructions found
here: Foreman :: Manual without an
issue. The hosts I'm trying to add aren't managed by Foreman - most of our
hosts are spun up in OpenStack and we're then using Katello as a repo
server and FreeIPA as the IDM. My questions are:
- When we install the katello-agent, the host appears in Foreman - is
there a way to automatically include the host in the realm we've configured? - If I manually add a host into the realm, I see a host entry in FreeIPA,
but it's not enrolled. The host OTP is indicated as set, but how do I get
this OTP so that I can enroll the client?
Thanks for your time.
Cheers!
