Help with upgrade gem within foreman
I wanna install a newer version of:
foreman_ansible 2.2.9
The 2.2.9 version i installed with:
apt-get install foreman_ansible
And now i wanna upgrade to newer version 2.3.0 because of existing issues.
with:
gem install --local foreman_ansible-2.3.0.gem
gem list
i can install the gem and see in my gemlist but foreman dont recognize.
How can i tell to foreman to use the right gem?
foreman 1.20.1-1
Ubuntu 16.04
Please help
mobios
scl enable tfm -- gem install --local foreman_ansible-2.3.0.gem
Oh you are on Ubuntu, not sure. @mmoll?
Long story short: Don’t try to do this. Also see https://github.com/theforeman/foreman-packaging/pull/3240 and the associated foreman_ansible problems…
thanks for your help (lzap and mmol)
