So I figured out that it only interprets the templates when you click the
build button on the host. If you change the template or add parameters to a
host/host group/environment/os, you must cancel the build and click build
again.
On Sep 1, 2011 12:19am, Corey Osman wrote:
Is foreman managing your tftp server? This is how foreman inserts the
initrd and kernal entries.
On Aug 31, 2011 9:51 PM, “lavaman” lavaman@gmail.com> wrote:
Groups “Foreman users” group.
> the build button on the host. If you change the template or add
> parameters to a host/host group/environment/os, you must cancel the
> build and click build again.
Yeah, if you use tftp I dont think there is a way to trigger anything
from foreman side…
Ohad
> the initrd and kernal entries.
> > On Aug 31, 2011 9:51 PM, "lavaman" lavaman@gmail.com> wrote:
> > You received this message because you are subscribed to the Google
> Groups "Foreman users" group.
> > To post to this group, send email to foreman-users@googlegroups.com.
> > To unsubscribe from this group, send email to
> foreman-users+unsubscribe@googlegroups.com.
> > For more options, visit this group at
> http://groups.google.com/group/foreman-users?hl=en.
Maybe you could trigger when dhcp grants a lease to a host in build mode?
I'm still interested in knowing more about how the templates work. It seems
that there are urls in foreman that use the name of the template that
appears on the template page, but the url for the kickstart template that
goes in the pxe template corresponds to a filename in app/view/unattended?
With the included templates, it's not clear what the relationship is between
the foreman name and the filename. It doesn't help that the wiki refers to a
template that is not included (provision), at least not in the rpm from the
yum repo.
> from foreman side…
> Ohad
> To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
> yum repo.
let me try clear it up a bit:
There are provisioning types/kinds:
PXELinux - tftp based pxebooting
gPXE - g/iPXE based booting
provision - kickstart, preseed, autoyast, jumpstart etc
finish - post installation scripts for OS's that support it (debian
late command, solaris etc)
script - something that returns a script, for example to update a
grub.conf of an existing system
PXEGrub - Grub base pxe booting (used only for intel solaris).
it depends on the template (settings --> configuration templates) to
which type of provisioning they apply to.
the templates which are defined in app/views/unattended, are used to
seed the database with working examples, they should not be modified
(they are left there for legacy compatibility, but have no useful
function).
After that, you need to assign the templates to os's etc as defined
here [1] and here [2]
from foreman side…
A little. I guess the problem i'm having is that i have a template of type
provision associated with an os. I've put a client with that os in build
mode and it will boot via pxe and run kickstart, but cannot use the ks url http://foreman/unattended/provision which is in the included pxe kickstart
default template. That url always returns an error stating that there is no
provision.erb in /app/views/unattended.
I’m still interested in knowing more about how the templates work. It
seems
With the included templates, it’s not clear what the relationship is
between
the foreman name and the filename. It doesn’t help that the wiki refers
to a
the
yum repo.
finish - post installation scripts for OS’s that support it (debian
function).
After that, you need to assign the templates to os’s etc as defined
from foreman side…
Sounds to me you didnt configure a default OS template… Settings -->
OS --> edit …
Ohad
>> > mode?
>> > seems
>> > that
>> > between
>> > to a
>> > the
>> > yum repo.
>> each of on this types, generate a url, e.g.
>> function).
>> Hope this clears up a bit,
>> Ohad
>> [1] http://theforeman.org/projects/foreman/wiki/Unattended_installations
>> [2] http://theforeman.org/projects/foreman/wiki/TemplateWriting
>> >> from foreman side...
>> >> Ohad
>> >> Groups
>> > Groups
A little. I guess the problem i’m having is that i have a template of
type
provision associated with an os. I’ve put a client with that os in build
kickstart
no
OS --> edit …
mode?
seems
that
between
refers
to a
from
the
yum repo.
function).
click
from foreman side…
type
build
kickstart
is no
OS --> edit …
mode?
It
seems
that
between
refers
to a
from
the
yum repo.
function).
click
anything
Google
Groups
> Actually, it was Kickstart default PXElinux
>> It's set to PXELinux and Kickstart PXE default…
Can you paste your foreman logs from when a host requests a kickstart?
does it work with spoof?
Ohad
On Thu, Sep 1, 2011 at 8:49 PM, lavaman wrote:
>>> > type
>>> > build
>>> > url
>>> > kickstart
>>> > is no
>>> Sounds to me you didnt configure a default OS template.. Settings -->
>>> OS --> edit ...
>>> Ohad
>>> >> > mode?
>>> >> > It
>>> >> > seems
>>> >> > that
>>> >> > that
>>> >> > between
>>> >> > refers
>>> >> > to a
>>> >> > from
>>> >> > the
>>> >> > yum repo.
>>> >> function).
>>> >> Ohad
>>> >> [1]
>>> >> >>> click
>>> >> >>> the
>>> >> >> anything
>>> >> >> Ohad
>>> >> >>> > inserts
>>> >> >>> > Google
>>> >> >> Groups
>>> >> > Groups
>>> >> Groups
>>> > Groups
build
mode?
It
seems
that
template
that
is
between
refers
to a
from
the
yum repo.
function).
click
the
anything
from foreman side…
inserts
Google
Groups
Groups
without thinking too much, it sounds to me like you dont have template
assigned to the host os, if you edit the host and click on
provisioning templates, does it show the right templates?
Ohad
On Thu, Sep 1, 2011 at 9:19 PM, lavaman wrote:
> I get the same error with a spoof or via kickstart. Here is the log entry
> from a spoof:
> Processing UnattendedController#provision (for 192.168.2.4 at 2011-08-31
> 21:22:10) [GET]
> Parameters: {"spoof"=>"192.168.0.3"}
> Found client.test.com
> ActionView::MissingTemplate (Missing template unattended/provision.erb in
> view path app/views):
> passenger (2.2.2) lib/phusion_passenger/rack/request_handler.rb:81:in
> `process_request'
> passenger (2.2.2) lib/phusion_passenger/abstract_request_handler.rb:203:in
> `main_loop'
> passenger (2.2.2)
> lib/phusion_passenger/railz/application_spawner.rb:340:in
> `start_request_handler'
> passenger (2.2.2)
> lib/phusion_passenger/railz/application_spawner.rb:298:in
> `handle_spawn_application'
> passenger (2.2.2) lib/phusion_passenger/utils.rb:181:in `safe_fork'
> passenger (2.2.2)
> lib/phusion_passenger/railz/application_spawner.rb:296:in
> passenger (2.2.2) lib/phusion_passenger/abstract_server.rb:337:in
> `__send__'
> `main_loop'
> passenger (2.2.2) lib/phusion_passenger/abstract_server.rb:187:in
> `start_synchronously'
> passenger (2.2.2) lib/phusion_passenger/abstract_server.rb:154:in `start'
> passenger (2.2.2)
> lib/phusion_passenger/railz/application_spawner.rb:192:in `start'
> passenger (2.2.2) lib/phusion_passenger/spawn_manager.rb:257:in
> `spawn_rails_application'
> passenger (2.2.2)
> lib/phusion_passenger/abstract_server_collection.rb:126:in `lookup_or_add'
> passenger (2.2.2) lib/phusion_passenger/spawn_manager.rb:251:in
> passenger (2.2.2)
> lib/phusion_passenger/abstract_server_collection.rb:80:in `synchronize'
> passenger (2.2.2)
> lib/phusion_passenger/abstract_server_collection.rb:79:in `synchronize'
> passenger (2.2.2) lib/phusion_passenger/spawn_manager.rb:250:in
> passenger (2.2.2) lib/phusion_passenger/spawn_manager.rb:153:in
> `spawn_application'
> passenger (2.2.2) lib/phusion_passenger/spawn_manager.rb:282:in
> `__send__'
> `main_loop'
> Rendering /usr/share/foreman/public/500.html (500 Internal Server Error)
>> >> It's set to PXELinux and Kickstart PXE default...
>> Ohad
>> >>> > of
>> >>> > type
>> >>> > build
>> >>> > ks
>> >>> > url
>> >>> > kickstart
>> >>> > there
>> >>> > is no
>> >>> OS --> edit ...
>> >>> Ohad
>> >>> >> > build
>> >>> >> > mode?
>> >>> >> > work.
>> >>> >> > It
>> >>> >> > seems
>> >>> >> > that
>> >>> >> > template
>> >>> >> > that
>> >>> >> > is
>> >>> >> > between
>> >>> >> > refers
>> >>> >> > to a
>> >>> >> > rpm
>> >>> >> > from
>> >>> >> > the
>> >>> >> > yum repo.
>> >>> >> to
>> >>> >> to
>> >>> >> modified
>> >>> >> function).
>> >>> >> Ohad
>> >>> >> [1]
>> >>> >> >>> click
>> >>> >> >>> the
>> >>> >> >> anything
>> >>> >> >> Ohad
>> >>> >> >>> > inserts
>> >>> >> >>> > Google
>> >>> >> >>> Google
>> >>> >> >> Google
>> >>> >> >> Groups
>> >>> >> > Google
>> >>> >> > Groups
>> >>> >> Groups
>> >>> > Groups
>> >>> Groups
>> > Groups
Yes. It shows the same templates that are assigned to the os.
template
of
type
in
build
the
ks
kickstart
there
is no
OS --> edit …
Ohad
On Thu, Sep 1, 2011 at 2:01 AM, Ohad Levy ohadlevy@gmail.com > >> >>> > wrote:
build
mode?
work.
It
seems
template
that
template
that
relationship
is
between
wiki
refers
to a
rpm
from
the
yum repo.
(debian
to
to
modified
function).
defined
inserts
Google
Groups
Groups
I'm just guessing, but can you try to have a simple one liner template
in your KS provisioning template?
Ohad
>> Ohad
>> > entry
>> > from a spoof:
>> > 21:22:10) [GET]
>> > in
>> > `process_request'
>> > passenger (2.2.2)
>> > `main_loop'
>> > passenger (2.2.2)
>> > passenger (2.2.2)
>> > passenger (2.2.2)
>> > `__send__'
>> > `main_loop'
>> > `start'
>> > passenger (2.2.2)
>> > passenger (2.2.2)
>> > `lookup_or_add'
>> > passenger (2.2.2)
>> > passenger (2.2.2)
>> > `spawn_application'
>> > `__send__'
>> > `main_loop'
>> >> Ohad
>> >> >>> > template
>> >> >>> > of
>> >> >>> > type
>> >> >>> > in
>> >> >>> > build
>> >> >>> > the
>> >> >>> > ks
>> >> >>> > url
>> >> >>> > kickstart
>> >> >>> > there
>> >> >>> > is no
>> >> >>> OS --> edit ...
>> >> >>> Ohad
>> >> >>> > On Thu, Sep 1, 2011 at 2:01 AM, Ohad Levy >> >> >>> > wrote:
>> >> >>> >> > build
>> >> >>> >> > mode?
>> >> >>> >> > work.
>> >> >>> >> > It
>> >> >>> >> > seems
>> >> >>> >> > template
>> >> >>> >> > that
>> >> >>> >> > template
>> >> >>> >> > that
>> >> >>> >> > relationship
>> >> >>> >> > is
>> >> >>> >> > between
>> >> >>> >> > wiki
>> >> >>> >> > refers
>> >> >>> >> > to a
>> >> >>> >> > rpm
>> >> >>> >> > from
>> >> >>> >> > the
>> >> >>> >> > yum repo.
>> >> >>> >> (debian
>> >> >>> >> a
>> >> >>> >> templates)
>> >> >>> >> to
>> >> >>> >> used
>> >> >>> >> to
>> >> >>> >> modified
>> >> >>> >> useful
>> >> >>> >> function).
>> >> >>> >> defined
>> >> >>> >> Ohad
>> >> >>> >> [1]
>> >> >>> >> >>> you
>> >> >>> >> >>> click
>> >> >>> >> >>> add
>> >> >>> >> >>> cancel
>> >> >>> >> >>> the
>> >> >>> >> >> anything
>> >> >>> >> >> Ohad
>> >> >>> >> >>> > inserts
>> >> >>> >> >>> > On Aug 31, 2011 9:51 PM, "lavaman" lavaman@gmail.com> >> >> >>> >> >>> > wrote:
>> >> >>> >> >>> > the
>> >> >>> >> >>> > Google
>> >> >>> >> >>> Google
>> >> >>> >> >> Google
>> >> >>> >> >> Groups
>> >> >>> >> > Google
>> >> >>> >> > Groups
>> >> >>> >> Google
>> >> >>> >> Groups
>> >> >>> > Google
>> >> >>> > Groups
>> >> >>> Groups
>> >> > Groups
>> >> Groups
>> > Groups
template
of
type
os
in
build
the
ks
pxe
kickstart
that
there
is no
OS --> edit …
Ohad
On Thu, Sep 1, 2011 at 2:01 AM, Ohad Levy ohadlevy@gmail.com > >> >> >>> > wrote:
On Thu, Sep 1, 2011 at 10:51 AM, lavaman lavaman@gmail.com > >> >> >>> >> wrote:
in
build
mode?
work.
It
seems
template
that
template
that
relationship
is
between
wiki
refers
to a
the
rpm
from
the
yum repo.
(debian
update
a
templates)
to
used
to
modified
useful
function).
defined
when
you
click
or
add
cancel
the
trigger
anything
from foreman side…
Ohad
On Sep 1, 2011 12:19am, Corey Osman <corey@logicminds.biz > > > >> >> >>> >> >>> wrote:
foreman
inserts
On Aug 31, 2011 9:51 PM, “lavaman” lavaman@gmail.com> > >> >> >>> >> >>> > wrote:
the
Google
Groups
