1.8 is quite old version so I'd recommend updating to the most recent version
first.
But in general, you should define these interfaces in host form. To create a
bond you have to define bonded interfaces first so create eth0 and eth1. Then
create a new interface of type bond and use identifiers that you used for eth0
and eth1 as bonded devices. Since you want to also create a vlan on top of the
bond, you have to define 4th vlan interface. To do it, keep type to Interface
but set the identifier to bond0.1 assuming the bond identifier was set to bond0.
Check virtual NIC checkbox and set the tag to 2 and attached to to bond0.
Repeat the steps above for all eth0-6, bond1-3 and vlans (bond1.2, bond2.3,
bond3.4) so 12 interfaces in total. Note that the networking info like subnet,
IP etc should be configured on vlan interfaces only. Just the mac address might
be needed on others.
If you want to make an interface that is being used for provisioning also part
of the bond, your switch should be configured to LACP passive since the bond is
configure as the last step of the provisioning. In other words, your switch
must allow non-aggregated traffic for provisioning and aggregated traffic for
communication afterwards.
I'm not entirely sure if provisioning can work if it requires a provisioning
interface traffic to be tagged. Maybe with native vlan.
I'm not a network expert so I'm sorry if I misunderstood something.
On Thursday 28 of July 2016 11:04:08 nilelinux . wrote:
> Hi All,
> Please I have installed Foreman version 1.8.0 on CentOS 7.1. I
> could provision CentOS to a HP blade server which has 6 NICs but I don't
> know how to configure Bonding on these interfaces. I would like to use
> Forman to configure Bonding as the following:-
> Eth0 and Eth1 for Bond1 in VLAN 2 with subnet 192.168.2.0/24.
> Eth2 and Eth3 for Bond2 in VLAN 3 with subnet 192.168.3.0/24 .
> Eth4 and Eth5 for Bond3 in VLAN 4 with subnet 192.168.4.0/24 .
> As I am new in Foreman technology, Could you simplify how to configure the
> Foreman to auto-configure the bonding.
> *Best Regards,*
> *Mostafa Yasin*
> Show trimmed content
Marek
Hello
when you build new host, there are several tabs for the form. Click Interfaces
form, then green "+ Add Interface" button. A modal window will appear where
you specify attributes I explained in last email. Once you're done with
Interfaces tab, let the host provision and verify that at the end (after final
reboot) the interfaces are configured according to what you defined in the form.
You can find some information in our manual too, see
https://www.theforeman.org/manuals/1.11/index.html#4.4.7Networking
Hope this helps
Marek
On Thursday 04 of August 2016 13:28:10 you wrote:
Hi Marek,
Thank you very much for your help. But I am a little bit confused as I am
new in Foreman Technology. So could you please type step by step (in a
simple way) what should I do to configure the network according to my
scenario.
Thanks in advance,
Regards,
Mostafa
Hi All,
don’t
the
Best Regards,
Mostafa Yasin
1.8 is quite old version so I’d recommend updating to the most recent
version
first.
a
Then
eth0
the
Interface
bond0.
bond2.3,
subnet,
might
part
bond is
switch
for
I’m not entirely sure if provisioning can work if it requires a
provisioning
I’m not a network expert so I’m sorry if I misunderstood something.
Marek
