How to import simple class.pp (not a module) and use it with foreman?
1.Attached a foreman debug file.
2.There are many issues with similar topic here… but none of them has a
short walk through of how to take a simple "class.pp" , import it to
foreman and apply it on hosts.
3. Env Details:
OS: redhat
RELEASE: CentOS release 6.6 (Final)
FOREMAN: 1.7.1
RUBY: ruby 1.8.7 (2013-06-27 patchlevel 374) [x86_64-linux]
PUPPET: 2.7.25
DENIALS: 0
4. Issue:
Trying to import this simple class to foreman and apply it on managed hosts.
class install-zabbix-agent {
yumrepo { "zabbix":
baseurl =>
"http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/",
descr => "zabbix repository",
enabled => 1,
gpgcheck => 0
    file { "/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX":
            mode    => 600,
            owner   => "root",
            group   => "root",
            source =>
"puppet:///files/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX",
require => yumrepo["zabbix"]
    package {
            "zabbix-agent-2.2.1-1.el6.x86_64":
            ensure => installed,
            require => file["/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX"],
    service { "zabbix-agent":
            ensure => running,
            enable => true,
            require => Package["zabbix-agent-2.2.1-1.el6.x86_64"],
    file { "/etc/zabbix/zabbix_agentd.conf":
            notify  => Service["zabbix-agent"],
            mode    => 600,
            owner   => "root",
            group   => "root",
            content => template('zabbix_agentd.conf.erb')
  1. This class works just fine on all of the puppet registered hosts ( if
    i use it manually via puppet agent ).
  2. What is the correct way to import it to foreman and apply it on other
    hosts ?
Thanks
foreman-debug-MutMp.tar.xz (8.33 KB)
So far the only way i found to imort and apply such a class with foreman is
by creating a module with the same name of the class
··· On Monday, January 12, 2015 at 1:04:43 PM UTC+2, imneo wrote: > > Hello, > > 1.Attached a foreman debug file. > > 2.There are many issues with similar topic here... but none of them has a > short walk through of how to take a simple "class.pp" , import it to > foreman and apply it on hosts. > > *3. Env Details:* > > OS: redhat > RELEASE: CentOS release 6.6 (Final) > FOREMAN: 1.7.1 > RUBY: ruby 1.8.7 (2013-06-27 patchlevel 374) [x86_64-linux] > PUPPET: 2.7.25 > DENIALS: 0 > > *4. Issue:* > > Trying to import this simple class to foreman and apply it on managed > hosts. > > class install-zabbix-agent { > yumrepo { "zabbix": > baseurl => " > http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/", > descr => "zabbix repository", > enabled => 1, > gpgcheck => 0 > } > > > file { "/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX": > mode => 600, > owner => "root", > group => "root", > source => > "puppet:///files/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX", > require => yumrepo["zabbix"] > } > > package { > "zabbix-agent-2.2.1-1.el6.x86_64": > ensure => installed, > require => file["/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX"], > } > > service { "zabbix-agent": > ensure => running, > enable => true, > require => Package["zabbix-agent-2.2.1-1.el6.x86_64"], > } > > file { "/etc/zabbix/zabbix_agentd.conf": > notify => Service["zabbix-agent"], > mode => 600, > owner => "root", > group => "root", > content => template('zabbix_agentd.conf.erb') > } > > } > > > 5. This class *works just fine* on all of the puppet registered hosts ( > if i use it manually via puppet agent ). > > 6. What is the correct way to import it to foreman and apply it on other > hosts ? > > Thanks > > > >
Just to be clear , if i have a simple class i should port it to be a module
and import it to foreman ?
That is the recommended way ?
Thank you for your help
The smart proxy only scans manifests in the modulepath, it doesn't check
the manifestdir, which is why it won't be imported automatically -
though conceivably it could.
That isn't a recommended or usual approach to using Puppet, so using a
module layout is a far better idea.
Note that hyphens in a class name are invalid and may cause problems, so
use underscores instead:
··· -- Dominic Cleal Red Hat Engineering
is by creating a module with the same name of the class
has a short walk through of how to take a simple "class.pp" , import
it to foreman and apply it on hosts.
*_3. Env Details:_*
  OS: redhat
  FOREMAN: 1.7.1
  PUPPET: 2.7.25
  DENIALS: 0
*_4. Issue:_*
*_
_*
managed hosts.
        yumrepo { "zabbix":
                baseurl =>
<http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/>",
                enabled => 1,
                gpgcheck => 0
                mode    => 600,
                owner   => "root",
                group   => "root",
                source =>
        package {
                ensure => running,
                enable => true,
                mode    => 600,
                owner   => "root",
                group   => "root",
hosts ( if i use it manually via puppet agent ).
other hosts ?
Thanks
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
Yes, exactly.
module and import it to foreman ?
*_3. Env Details:_*
  OS: redhat
  FOREMAN: 1.7.1
  PUPPET: 2.7.25
  DENIALS: 0
*_4. Issue:_*
*_
_*
managed hosts.
        yumrepo { "zabbix":
                baseurl =>
                enabled => 1,
                gpgcheck => 0
                mode    => 600,
                owner   => "root",
                group   => "root",
                source =>
        package {
                ensure => running,
                enable => true,
                mode    => 600,
                owner   => "root",
                group   => "root",
other hosts ?
Thanks
