I’m trying to setup bonding on some bare metal servers. Some of our servers have cables connected for eth1 but not eth2, but sometimes it’s the other way around. Is there a flag in Forman I can use to determine if one of these network interfaces are up? I suspect the “link” boolean carries this information, but I haven’t been able to find a doc that says what the variables mean.
This is a snippet from the kickstart script. It shows the interfaces list that prints out eth1 & eth2 (among other interfaces)
<% @host.interfaces.each do |interface| %>
<%= interface.identifier %>
This dumps out the data being fed into the kickstart script
<%= host_enc %>
Looking at that data dump, I noticed these contents about the network interface:
“virtual” => false,
"link" => true,
“identifier” => “eth2”,
“managed” => false,
“primary” => false,
“provision” => false,
“subnet” => nil,
“subnet6” => nil,
“tag” => nil,
“attached_to” => nil,
“type” => “Interface”
“ip” => nil,
“ip6” => nil,
“mac” => “e4:43:4b:3b:38:43”,
“name” => nil,
“attrs” => {
“mtu” => 1500, “duplex” => “unknown! (255)”, “port” => “Other”, “auto_negotiation” => “false”, “wol” => true
I noticed that “link” is true here. This is a network interface that works. On a couple that didn’t work, it was false. Is this the correct variable to tell me if the network interface has a physical cable attached? Or is there something else I should be doing?
If there are docs that explain what these different parameters/functions do in the kickstart script, I’d appreciate a link. I’ve been looking here: https://projects.theforeman.org/projects/foreman/wiki/TemplateWriting
Foreman version: 1.21.0
Smart proxy version: 1.24.2
Thanks!
