after my hosts are discovered successfully they will automatically assigned
to the correct hostgroup and Environment and added to hosts registry.
But the host must be restarted manually. After discovery detection it hangs
in the screen from the picture.
After I press reboot, all works as expected.
Have you enabled reboot(discovery_reboot) option in Settings>Discovered?
On Thursday, November 10, 2016 at 2:49:45 PM UTC, Christian Froestl wrote:
> Hi all,
> assigned to the correct hostgroup and Environment and added to hosts
> registry.
> hangs in the screen from the picture.
> How can I configure a automatically reboot?
> Kind regards,
> Christian
I found the following exception in the production log.
2016-11-11 09:52:08 [app] [I] Rendered home/_user_dropdown.html.erb
(2.2ms)
2016-11-11 09:52:08 [app] [I] Read fragment views/tabs_and_title_records-3
(0.2ms)
2016-11-11 09:52:08 [app] [I] Rendered home/_topbar.html.erb (9.2ms)
2016-11-11 09:52:08 [app] [I] Rendered layouts/base.html.erb (10.3ms)
2016-11-11 09:52:08 [app] [I] Filter chain halted as :welcome rendered or
redirected
2016-11-11 09:52:08 [app] [I] Completed 200 OK in 30ms (Views: 13.9ms |
ActiveRecord: 3.0ms)
2016-11-11 09:52:08 [app] [W] Failed to communicate with graphite:
Connection refused - connect(2) for "0.0.0.0" port 2003
2016-11-11 09:52:22 [app] [I] Started POST "/api/v2/discovered_hosts/facts"
for 10.0.2.15 at 2016-11-11 09:52:22 +0100
2016-11-11 09:52:22 [app] [I] Processing by
Api::V2::DiscoveredHostsController#facts as JSON
2016-11-11 09:52:22 [app] [I] Parameters: {"facts"=>"[FILTERED]",
"apiv"=>"v2", "discovered_host"=>{"facts"=>"[FILTERED]"}}
2016-11-11 09:52:22 [app] [I] Import facts for 'mac080027b4d94a' completed.
Added: 65, Updated: 0, Deleted 0 facts
2016-11-11 09:52:22 [app] [I] Detected subnet: Dev (172.16.4.0/24) with
taxonomy ["SSW-Trading GmbH"]/["Oststeinbek"]
2016-11-11 09:52:22 [app] [I] Assigned location: Oststeinbek
2016-11-11 09:52:22 [app] [I] Assigned organization: SSW-Trading GmbH
2016-11-11 09:52:22 [app] [I] Locking discovered host 08:00:27:b4:d9:4a in
subnet Dev (172.16.4.0/24)
2016-11-11 09:52:22 [app] [I] Match found for host mac080027b4d94a (34)
rule Disco_Dev (4)
2016-11-11 09:52:24 [app] [I] Create DHCP reservation for
mac080027b4d94a.example.com-08:00:27:b4:d9:4a/172.16.4.9
2016-11-11 09:52:24 [app] [I] Add DNS A record for mac080027b4d94a.example.com/172.16.4.9
2016-11-11 09:52:24 [app] [I] Add DNS PTR record for
172.16.4.9/mac080027b4d94a.example.com
2016-11-11 09:52:26 [app] [W] Unable to reboot mac080027b4d94a
> RestClient::InternalServerError: 500 Internal Server Error
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/abstract_response.rb:74:in return!' > /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:495:inprocess_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:421:in block in transmit' > /opt/rh/rh-ruby22/root/usr/share/ruby/net/http.rb:853:instart'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:413:in transmit' > /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:176:inexecute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:41:in execute' > /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/resource.rb:76:input'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-6.0.0/app/services/foreman_discovery/node_api/node_resource.rb:102:in put' > /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-6.0.0/app/services/foreman_discovery/node_api/power_service.rb:8:inreboot'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-6.0.0/app/models/host/discovered.rb:181:in reboot' > /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-6.0.0/app/models/host/managed_extensions.rb:31:insetReboot'
> /usr/share/foreman/app/models/concerns/orchestration.rb:162:in execute' > /usr/share/foreman/app/models/concerns/orchestration.rb:107:inblock in
process'
> /usr/share/foreman/app/models/concerns/orchestration.rb:99:in each' > /usr/share/foreman/app/models/concerns/orchestration.rb:99:inprocess'
> /usr/share/foreman/app/models/concerns/orchestration.rb:39:in post_commit' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:inblock in make_lambda'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:263:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:263:inblock in simple'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:506:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:506:inblock in call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:506:in each' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:506:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in __run_callbacks__' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in_run_commit_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:314:in committed!' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:89:incommit_records'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:153:in commit' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:175:incommit_transaction'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:194:in within_new_transaction' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:intransaction'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:220:in transaction' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:348:inwith_transaction_returning_status'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:286:in block in save' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:301:inrollback_active_record_state!'
…skipping…
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/mapper.rb:49:in serve' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:43:inblock in serve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in each' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:inserve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:815:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in call' > /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.6/lib/apipie/static_dispatcher.rb:65:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.6/lib/apipie/extractor/recorder.rb:132:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.3.6/lib/apipie/middleware/checksum_in_headers.rb:27:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/etag.rb:24:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/conditionalget.rb:38:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/head.rb:13:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/params_parser.rb:27:in call' > /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/flash.rb:260:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:225:incontext'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:220:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/cookies.rb:560:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/query_cache.rb:36:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:29:in block in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:88:inrun_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in _run_call_callbacks' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:inrun_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:27:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/remote_ip.rb:78:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/show_exceptions.rb:30:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:38:in call_app' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:22:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/request_id.rb:21:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/methodoverride.rb:22:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/runtime.rb:18:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/cache/strategy/local_cache_middleware.rb:28:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/sendfile.rb:113:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:518:in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:165:incall'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in public_send' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:inmethod_missing'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:66:in block in call' > /opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:ineach'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in call' > /usr/share/passenger/phusion_passenger/rack/thread_handler_extension.rb:74:inprocess_request'
/usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:141:in accept_and_process_next_request' > /usr/share/passenger/phusion_passenger/request_handler/thread_handler.rb:109:inmain_loop'
> /usr/share/passenger/phusion_passenger/request_handler.rb:455:in block (3 levels) in start_threads' > /opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:incall'
`block in create_with_logging_context'
2016-11-11 09:52:26 [app] [I] Completed 201 Created in 3725ms (Views: 1.9ms
> ActiveRecord: 194.0ms)
2016-11-11 09:52:26 [app] [W] Failed to communicate with graphite:
Am Donnerstag, 10. November 2016 15:49:45 UTC+1 schrieb Christian Froestl:
> Hi all,
> registry.
> Kind regards,
> Christian
Am Donnerstag, 10. November 2016 17:14:24 UTC+1 schrieb Akash Kaveti:
> Hi Christian,
>> Hi all,
>> registry.
>> Kind regards,
>> Christian
Reboot happens via an API call to a cut-down Foreman-proxy running on the
discovered host. It looks like that service is returning a 500 when told to
reboot - but you'll need to get onto the host to the logs of that.
The Discovery docs cover enabling SSH on the Discovery Image, so you'll
want to do that and then see if you can get the proxy log when it's told to
reboot.
What Greg said, also you can configure Smart Proxy as a http/https
proxy for discover calls, depending on if you have selected Discovery
Proxy for the Subnet the host was discovered in or not. Then the call
will be proxied, you need to enable Discovery Smart Proxy plugin.
Check our documentation, it's all there.
LZ
> The Discovery docs cover enabling SSH on the Discovery Image, so you'll want
> reboot.
> Cheers
> Greg
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
I have done all configuration
from Foreman :: Plugin Manuals,
but it's still not working.
I try to use the discovery proxy for this and have made the following
configuration:
The discovery proxy is active in the smart proxy settings, but when I go
into the Smart Proxy -> Services under Discovery I see Version 1.0.4 and
"Data not available for Discovery". Is that right?
If I change the APPEND line to proxy_type forman, the automatic reboot is
successfull.
I logged me into the discovered host by ssh, but there are no logfiles
unter /var/log/foreman-proxy/.
Any idea whats going wrong with the foreman-proxy?
Am Freitag, 11. November 2016 13:49:09 UTC+1 schrieb Lukas Zapletal:
> LZ
> On Fri, Nov 11, 2016 at 12:24 PM, Greg Sutcliffe > <greg.su...@gmail.com > wrote:
> the
> to
> want
> > reboot.
> > Cheers
> > Greg
> Groups
> an
> > email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com
> Later,
> Lukas @lzap Zapletal
Correct
> successfull.
It must be proxy.type (note the dot character). Also make sure the
APPEND line is on one line without any breaks.
> I logged me into the discovered host by ssh, but there are no logfiles unter
See journalctl for some relevant data.
Nope, use foreman-tail when discovering both on Smart Proxy and
Foreman instance and paste bin output. Do you see requests hitting
Smart Proxy? What HTTP code does it return? Does it get proxied
through to Foreman app? Again, what is the result?
what irritates me a little is, that my PXELinux global default entry does not have the port of the server. But in most documentation pages (including this: Provisioning Guide, it is always with 8443 for the port. Can this be the problem? I never changed it. That was set up the automated setup of the plugin.
