While trying to correct some provisioning issues and updating the katello
instance I get the folowing error. "Upgrade step import_distributions
failed. Check logs for more information."
A tail of the log gives me this
/opt/rh/rh-ror41/root/usr/share/gems/gems/activerecord-4.1.5/lib/active_record/relation/delegation.rb:46:in each' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/models/katello/repository.rb:511:inimport_distributions'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/lib/katello/tasks/upgrades/2.4/import_distributions.rake:8:in
`block (4 levels) in <top (required)>'
Tasks: TOP => katello:upgrades:2.4:import_distributions
Importing distribution data into repositories
On Friday, 23 September 2016 01:32:06 UTC+5:30, Rick Langston wrote:
Hi
instance I get the folowing error. “Upgrade step import_distributions
failed. Check logs for more information.”
/opt/rh/rh-ror41/root/usr/share/gems/gems/activerecord-4.1.5/lib/active_record/relation/delegation.rb:46:in each' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/models/katello/repository.rb:511:in import_distributions’
`block (4 levels) in <top (required)>’
Thank you
I tried that one but its a persistent one for sure. I even tried to
manipulate the product with hammer and it refused also.
I was just going to leave it in until I ran across this upgrade issue which
seems to be forcing my hand.
On Friday, September 23, 2016 at 3:18:13 AM UTC-5, Unix SA wrote:
> foreman-rake katello:delete_orphaned_content
> may be this can help?
>> Hi
>> `each'
>> `import_distributions'
>> `block (4 levels) in '
>> [ERROR 2016-09-22 14:50:35 main] Upgrade step import_distributions
>> [DEBUG 2016-09-22 14:50:35 main] Cleaning
>> /etc/foreman-installer/scenarios.d/d20160922-2138-p01ysa
>> [DEBUG 2016-09-22 14:50:35 main] Cleaning /tmp/default_values.yaml
>> I have concerns about the katello:upgrades:2.4:import_distributions
>> statement above as this is a 3.0 installation.
>> I think this maybe due to a the orphaned Redhat directory product that is
>> left over from another time and that account is no longer valid.
>> Any help in getting this product removed would be greatly appreciated.
>> Thank you
