we have configured foreman to build a new host with the following steps:
using discovery during boot
provision to hostgroup via foreman GUI
Using PXE boot with a Kickstart PXELinux template
Running provisioning template after PXE boot
These steps works well, but the finish template will not run.
It is defined in the operating system like the provisioning template and
should run command on the target server.
I do not even the a connection via Ssh on the target server. Which Username
is used for ssh connection for the finish template. (and where to configure)
And I don't even see any activities in foreman-tail regarding the finish
template.
What you can do as a workaround, you can use post section in Anaconda
to download and run it yourself, or schedule a firstboot script.
Running it against non-image based deployments might be useful, feel
free to send a patch for that. Direct SSH connection is required from
Foreman then, be aware!
LZ
On Fri, Jan 27, 2017 at 9:06 AM, Christian Froestl wrote:
> Hi all,
> 1. using discovery during boot
> 2. provision to hostgroup via foreman GUI
> 3. Using PXE boot with a Kickstart PXELinux template
> 4. Running provisioning template after PXE boot
> template.
> Please help.
> Kind regards,
> Christian
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
