How can one see the documentation of a plugin that was installed using rpm?
For example, I installed wreckingball ( including wreckingball-doc), there are 2 directories ( ri and rdoc with files in them) so I am assuming there should be a way to read the docs
Just to clarify, clicking on “documentation” link provided by foreman is just listing generic documentation
and https://myserver/foreman.html page does not exist
What am I missing / doing wrong ?
What exactly is a valid URL for seeing installed plugin documentation ?
Thanks for taking the trouble to dig a bit into this
Assuming I just picked the wrong plugin as an example for my issue, are you saying that a better documented plugin will have its documentation available at https://server/foreman.html ?
