Howto mirror RPM Azul Zulu OpenJDK in Katello with repo not in yum format
I read the manual Install Azul Zulu on RPM-based Linux (RHEL, SLES, Oracle Linux)
The repo have only index.yml and not yum format.
how i do build the repo in foreman/katello
System Information
Foreman Version 3.6.1 © 2009-2023
Name Description Author Version
foreman-tasks The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks. Ivan Nečas 7.2.1
foreman_acd Foreman plugin to provide application centric deployment and self service portal ATIX AG 0.9.4
foreman_ansible Ansible integration with Foreman Daniel Lobato Garcia 11.2.0
foreman_azure_rm This gem provides Azure Resource Manager as a compute resource for The Foreman Aditi Puntambekar, Shimon Shtein, and Tyler Gregory 2.2.9
foreman_bootdisk Plugin for Foreman that creates iPXE-based boot disks to provision hosts without the need for PXE infrastructure. Dominic Cleal 21.0.4
foreman_column_view Displays an additional column in the Foreman Hosts view and/or additional entries in the Host show page Greg Sutcliffe 0.4.0
foreman_discovery MaaS Discovery Plugin engine for Foreman Aditi Puntambekar, alongoldboim, Alon Goldboim, amirfefer, Amit Karsale, Amit Upadhye, Amos Benari, Avi Sharvit, Bryan Kearney, bshuster, Daniel Lobato, Daniel Lobato Garcia, Daniel Lobato García, Danny Smit, David Davis, Djebran Lezzoum, Dominic Cleal, Dominik Matoulek, Eric D. Helms, Ewoud Kohl van Wijngaarden, Frank Wall, Greg Sutcliffe, ChairmanTubeAmp, Ido Kanner, imriz, Imri Zvik, Ivan Nečas, Jan Matusz, John Mazzie, Joseph Mitchell Magen, June Zhang, kgaikwad, Lars Berntzon, ldjebran, Leos Stejskal, Lukas Zapletal, Lukáš Zapletal, Marek Hulan, Marek Hulán, MariaAga, Martin Bačovský, Matt Jarvis, Michael Moll, Nick, odovzhenko, Ohad Levy, Ondrej Prazak, Ondřej Ezr, Ori Rabin, orrabin, Partha Aji, Petr Chalupa, Phirince Philip, Rahul Bajaj, Robert Antoni Buj Gelonch, Ron Lavi, Scubafloyd, Sean O'Keeffe, Sebastian Gräßl, Shimon Shtein, Shlomi Zadok, Stephen Benjamin, Swapnil Abnave, Thomas Gelf, Timo Goebel, Tomas Strych, Tom Caspy, Tomer Brisker, and Yann Cézard 22.0.4
foreman_expire_hosts A Foreman plugin that allows hosts to expire at a configurable date. Hosts will be shut down and automatically deleted after a grace period. Nagarjuna Rachaneni and Timo Goebel 8.1.0
foreman_hooks Plugin engine for Foreman that enables running custom hook scripts on Foreman events Dominic Cleal 0.3.17
foreman_kubevirt Provision and manage Kubevirt Virtual Machines from Foreman. Moti Asayag 0.1.9
foreman_leapp A Foreman plugin to support inplace RHEL upgrades with Leapp utility. Foreman Leapp team 0.1.13
foreman_openscap Foreman plug-in for managing security compliance reports slukasik@redhat.com 6.0.0
foreman_remote_execution A plugin bringing remote execution to the Foreman, completing the config management functionality with remote management functionality. Foreman Remote Execution team 9.1.0
foreman_setup Plugin for Foreman that helps set up provisioning. Dominic Cleal 8.0.1
foreman_snapshot_management Foreman-plugin to manage snapshots in a virtual-hardware environments. ATIX AG 2.0.3
foreman_statistics Statistics and Trends for Foreman gives users overview of their infrastructure. Ondrej Ezr 2.0.1
foreman_templates Engine to synchronise provisioning templates from GitHub Greg Sutcliffe 9.3.0
foreman_webhooks Plugin for Foreman that allows to configure Webhooks. Timo Goebel 3.0.5
katello Katello adds Content and Subscription Management to Foreman. For this it relies on Candlepin and Pulp. N/A 4.8.1
Repos for DEB works fine
Follow all URL in the manual below to get GPG key et repos
Manual: Install Azul Zulu on Debian-based Linux
Regards
Just had a look at their install docs, looks like you can add it like this:
upstream URI: https://repos.azul.com/zulu/rpm/
GPG key: https://assets.azul.com/files/0xB1998361219BD9C9.txt
This is basically the content of the zulu-repo-1.0.0-1.noarch.rpm package :slightly_smiling_face:
They do not work. Missing some index file
This exemple below is good for yum repository.
You cans see the conten below
This repository does not have the structure of an RPM repository.
No sub-folders present
Hmmm this looks different from what I see on https://repos.azul.com/zulu/rpm/ :
But https://repos.azul.com/zulu/rpm/repodata/repomd.xml shows the repomd xml so it’s definitely a yum repo :thinking:
Btw, why shows your error Index of /zulu/bin ?
And you made me daubt my own tests :laughing:
So I retested:
And to make sure I will download the whole content including the artifacts now.
Yup download looks all good :+1:
Thank you for your helping
