I am running Version 0.4.2 and I ran into an issue when trying to put this
into one of the provisioning templates (<%= @host.subnet.gateway %>). I
also tried this <%= subnet.gateway %>. Can I work around it with out
upgrading?
– thanks,
David Garvey
First you'll have to tell us what error you hit
Greg
upgrading?
Yeah Right Greg,
Here is the error. I don't see a place where subnet gateway is defined
either. subnet mask works: <%= @host.subnet.mask %>
template: undefined local variable or method `subnet' for
#<ActionView::Base:0x7f473560c100>
On Thu, May 23, 2013 at 3:59 AM, Greg Sutcliffe wrote:
this into one of the provisioning templates (<%= @host.subnet.gateway %>).
I also tried this <%= subnet.gateway %>. Can I work around it with out
upgrading?
First you’ll have to tell us what error you hit
Greg
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
David Garvey
As far as i recall, I think @host.subnet.gateway should work in 0.4.
However, that error doesn't look right at all, what template are you adding
that to?
On 23 May 2013 17:17, david.garvey@gmail.com wrote:
Yeah Right Greg,
Here is the error. I don’t see a place where subnet gateway is defined
template: undefined local variable or method `subnet’ for #ActionView::Base:0x7f473560c100
Greg,
It's a provisioning template. I am trying to export some bash variables so
i can write the network info into the file system.
/usr/bin/chvt 3
export IPADDR=<%= @host.ip %>
export GATEWAY=<%= subnet.gateway %>
export MACADDR=<%=@host.mac %>
export NETMASK=<%= @host.subnet.mask %>
export HOSTNAME=<%= @host %>
configure static IP address for eth0
cat << EOF > /etc/sysconfig/network-scripts/ifcfg-eth0
DEVICE=eth0
ONBOOT=yes
BOOTPROT=static
TYPE=ethernet
IPADDR=$IPADDR
NETMASK=$NETMASK
HWADDR=$MACADDR
EOF
ipcalc -b $IPADDR $NETMASK >> /etc/sysconfig/network-scripts/ifcfg-eth0
ipcalc -n $IPADDR $NETMASK >> /etc/sysconfig/network-scripts/ifcfg-eth0
NETWORKING=yes
NETWORKING_IPV6=no
#GATEWAY=$GATEWAY
HOSTNAME=$HOSTNAME
EOF
On Thu, May 23, 2013 at 9:37 AM, Greg Sutcliffe wrote:
On 23 May 2013 17:17, david.garvey@gmail.com david.garvey@gmail.comwrote:
Yeah Right Greg,
However, that error doesn’t look right at all, what template are you adding
that to?
David Garvey
> Greg,
Fair enough. Occaionally people try to attach the Default PXE Template to a
host, which it isn't really designed for and that can cause weird errors,
hence my question.
I wouldn't expect that to work. In my test <%= @host.subnet.gateway %> was
fine, as was <%= @host.subnet %>. Does the latter work for you? You should
get something like "192.168.122.0/24"
Greg
On 23 May 2013 17:58, david.garvey@gmail.com wrote:
Thanks Greg,
This works: <%= @host.subnet %>
Template:
export GATEWAY=<%= @host.subnet %>
Results:
export IPADDR=10.2.10.20
export GATEWAY=10.2.10.0/22
export MACADDR=46:25:a5:51:b5:db
export NETMASK=255.255.245.0
export HOSTNAME=test09.sjc.collab.net
On Thu, May 23, 2013 at 10:32 AM, Greg Sutcliffe wrote:
On 23 May 2013 17:58, david.garvey@gmail.com david.garvey@gmail.comwrote:
Greg,
It’s a provisioning template. I am trying to export some
bash variables so i can write the network info into the file system.
a host, which it isn’t really designed for and that can cause weird errors,
hence my question.
I wouldn’t expect that to work. In my test <%= @host.subnet.gateway %> was
get something like “192.168.122.0/24”
Greg
David Garvey
Greg,
Where in the UI do I define <%= @host.subnet.gateway %>?
On Thu, May 23, 2013 at 11:10 AM, david.garvey@gmail.com < david.garvey@gmail.com> wrote:
Thanks Greg,
Template:
Results:
On Thu, May 23, 2013 at 10:32 AM, Greg Sutcliffe <greg.sutcliffe@gmail.com > > wrote:
Greg,
hence my question.
was fine, as was <%= @host.subnet %>. Does the latter work for you? You
should get something like “192.168.122.0/24”
Greg
David Garvey
David Garvey
So to recap, you're saying <%= @host.subnet %> works fine but <%=
@host.subnet.gateway %> does not? If so, does your Subnet (More -> Subnets
-> Edit the appropriate subnet) have a gateway set. If so, what's the exact
error that @host.subnet.gateway gives you?
Greg
On 23 May 2013 19:18, david.garvey@gmail.com wrote:
Greg,
Greg,
I don't see a place to put the subnet gateway.
I just have the following fields. Name,Domain,Network,Netmask,Dhcp,Tftp
On Thu, May 23, 2013 at 11:27 AM, Greg Sutcliffe wrote:
On 23 May 2013 19:18, david.garvey@gmail.com david.garvey@gmail.comwrote:
Greg,
So to recap, you’re saying <%= @host.subnet %> works fine but <%=
-> Edit the appropriate subnet) have a gateway set. If so, what’s the exact
Greg
David Garvey
Greg,
It returns the not defined error:
export GATEWAY=<%=@host.subnet.gateway %>
template: undefined method `gateway' for
#<ActiveRecord::Associations::BelongsToAssociation:
On Thu, May 23, 2013 at 11:43 AM, david.garvey@gmail.com < david.garvey@gmail.com> wrote:
Greg,
I don’t see a place to put the subnet gateway.
On Thu, May 23, 2013 at 11:27 AM, Greg Sutcliffe <greg.sutcliffe@gmail.com > > wrote:
Greg,
Greg
David Garvey
David Garvey
Cool Thanks Guys,
That what I figured. I am reading new docs for an outdated build.
On Thu, May 23, 2013 at 1:23 PM, david.garvey@gmail.com < david.garvey@gmail.com> wrote:
Greg,
template: undefined method `gateway’ for #<ActiveRecord::Associations::BelongsToAssociation:
On Thu, May 23, 2013 at 11:43 AM, david.garvey@gmail.com < > david.garvey@gmail.com> wrote:
Greg,
On Thu, May 23, 2013 at 11:27 AM, Greg Sutcliffe < >> greg.sutcliffe@gmail.com> wrote:
Greg,
Greg
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com.
David Garvey
David Garvey
David Garvey
Greg,
gateway and vlan id etc was added in a later release. 1.0 I believe.
On Thu, May 23, 2013 at 8:43 PM, david.garvey@gmail.com < david.garvey@gmail.com> wrote:
Thanks for correcting me Mikael, I though that was in 0.4 - clearly not
David, 0.4 is nearly 2 years old, so you want all that new shinyness, yes?
On 23 May 2013 21:29, david.garvey@gmail.com wrote:
Cool Thanks Guys,
Yes,
David likes shinyness… Foreman is beautiful even in it's infancy.
Thanks again,
On Fri, May 24, 2013 at 3:00 AM, Greg Sutcliffe wrote:
On 23 May 2013 21:29, david.garvey@gmail.com david.garvey@gmail.comwrote:
Cool Thanks Guys,
David Garvey
