I receive an undefined method error when submitting a remote execution job
I used the foreman-installer to upgrade from 1.15.6 to 1.16.0 recently. So I’m at 1.16.0 right now. I wanted to use the remote execution plugin, so I installed that using the foreman-installer. I enabled the foreman_plugin_remote_execution and foreman_proxy_plugin_remote_execution_ssh plugins. The installation finished successfully.
Next I tried to run a job on a host. After submitting the job and trying to view it from the /job_invocations page, I receive an error: undefined methodabort_foreman_tasks_task_path’`
My foreman is running on the latest CentOS 7.
Here is the full stack trace:
NoMethodError
undefined method `abort_foreman_tasks_task_path' for #<#<Class:0x007fb248a07330>:0x007fb24a29fb40>
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-1.3.7/app/helpers/remote_execution_helper.rb:125:in `job_invocation_task_buttons'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-1.3.7/app/views/job_invocations/show.html.erb:6:in `_72f333be8a1b58ac9e055b269f01287a'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/template.rb:145:in `block in render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:166:in `instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/template.rb:333:in `instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/template.rb:143:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.2.0/lib/deface/action_view_extensions.rb:41:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/template_renderer.rb:54:in `block (2 levels) in render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/abstract_renderer.rb:39:in `block in instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `block in instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/abstract_renderer.rb:39:in `instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/template_renderer.rb:53:in `block in render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/template_renderer.rb:61:in `render_with_layout'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/template_renderer.rb:52:in `render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/template_renderer.rb:14:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/renderer.rb:46:in `render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/renderer/renderer.rb:27:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:100:in `_render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/streaming.rb:217:in `_render_template'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:83:in `render_to_body'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:32:in `render_to_body'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/renderers.rb:37:in `render_to_body'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/rendering.rb:25:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:16:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/core_ext/benchmark.rb:12:in `block in ms'
/opt/rh/rh-ruby22/root/usr/share/ruby/benchmark.rb:303:in `realtime'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/core_ext/benchmark.rb:12:in `ms'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/railties/controller_runtime.rb:25:in `cleanup_view_runtime'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:43:in `render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/implicit_render.rb:10:in `default_render'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/implicit_render.rb:5:in `send_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:198:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rendering.rb:10:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:117:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:505:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:498:in `block (2 levels) in around'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:313:in `block (2 levels) in halting'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:312:in `block in halting'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:497:in `block in around'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.4.1/lib/audited/sweeper.rb:14:in `around'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in `public_send'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:455:in `block in make_lambda'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in `run_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rescue.rb:29:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:137:in `process'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:30:in `process'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:196:in `dispatch'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:237:in `block in action'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `each'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `serve'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:815:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/extractor/recorder.rb:136:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/static.rb:116:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.4/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/etag.rb:24:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/conditionalget.rb:25:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/head.rb:13:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/flash.rb:260:in `call'
/usr/share/foreman/lib/middleware/session_safe_logging.rb:17:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:225:in `context'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/session/abstract/id.rb:220:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/query_cache.rb:36:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:22:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.0/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/usr/share/foreman/lib/middleware/tagged_logging.rb:18:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/methodoverride.rb:22:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/runtime.rb:18:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/cache/strategy/local_cache_middleware.rb:28:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/sendfile.rb:113:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-3.4.1/lib/secure_headers/middleware.rb:12:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:518:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/application.rb:165:in `call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `public_send'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `method_missing'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:66:in `block in call'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in `each'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/rack-1.6.2/lib/rack/urlmap.rb:50:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in `block in create_with_logging_context'
Is this something wrong with my installation or is it bug? Any help would be appreciated.
Do you have the foreman-tasks plugin installed as well? If so, what version is it? The abort action was only added in version 0.9.5 of foreman-tasks, which should have been installed as a dependency of remote execution 1.3.7 but possibly it wasn’t for some reason.
@Adam_Ruzicka - any other insights?
Tomer Brisker
In 1.15 we have foreman-tasks-0.9.6 and in 1.16 we have foreman-tasks-0.10.0, both should contain the code for aborting tasks. One thing that comes to mind is that just pulling in the RPM isn’t enough and it needs to be enabled.
@bkrisch could you please try running the installer again with additional --enable-foreman-plugin-tasks flag?
This is not an isuse on Brian’s setup.
The problem lies here
Deploy dynflow-executor service via Foreman package by dLobatog · Pull Request #1549 · theforeman/foreman-packaging · GitHub, which
was a dependnecy for
Rpm/foreman tasks 0.10.3 [rpm] by iNecas · Pull Request #1821 · theforeman/foreman-packaging · GitHub.
As I’ve suggested in
@Greg_Sutcliffe1 I think I’ve hit a bug with Discourse here, my message in e-mail reply looked like this:
As I've suggested in https://github.com/theforeman/foreman-packaging/pull/1549#issuecomment-350983953,
I will revert the changes in tasks that caused this troubles and release a new version
that will still ship the service scripts in 1.16
See what Discourse did to it.
I guess we should disable this fancy thing or replacing links with some divs, as it doesn’t seem to work reliably
– Ivan
I did have the foreman-tasks installed as well. Here’s the main menu of my foreman-installer
Main Config Menu
  1. [✓] Configure foreman
  2. [✓] Configure foreman_cli
  3. [✗] Configure foreman_cli_openscap
  4. [✓] Configure foreman_proxy
  5. [✓] Configure puppet
  6. [✗] Configure foreman_plugin_ansible
  7. [✗] Configure foreman_plugin_azure
  8. [✗] Configure foreman_plugin_bootdisk
  9. [✗] Configure foreman_plugin_chef
  10. [✗] Configure foreman_plugin_cockpit
  11. [✗] Configure foreman_plugin_default_hostgroup
  12. [✓] Configure foreman_plugin_dhcp_browser
  13. [✗] Configure foreman_plugin_digitalocean
  14. [✗] Configure foreman_plugin_discovery
  15. [✗] Configure foreman_plugin_docker
  16. [✗] Configure foreman_plugin_expire_hosts
  17. [✗] Configure foreman_plugin_hooks
  18. [✗] Configure foreman_plugin_host_extra_validator
  19. [✗] Configure foreman_plugin_memcache
  20. [✗] Configure foreman_plugin_monitoring
  21. [✗] Configure foreman_plugin_omaha
  22. [✗] Configure foreman_plugin_openscap
  23. [✗] Configure foreman_plugin_ovirt_provision
  24. [✗] Configure foreman_plugin_puppetdb
  25. [✓] Configure foreman_plugin_remote_execution
  26. [✗] Configure foreman_plugin_salt
  27. [✓] Configure foreman_plugin_setup
  28. [✓] Configure foreman_plugin_tasks
  29. [✓] Configure foreman_plugin_templates
  30. [✗] Configure foreman_compute_ec2
  31. [✗] Configure foreman_compute_gce
  32. [✗] Configure foreman_compute_libvirt
  33. [✗] Configure foreman_compute_openstack
  34. [✗] Configure foreman_compute_ovirt
  35. [✗] Configure foreman_compute_rackspace
  36. [✓] Configure foreman_compute_vmware
  37. [✗] Configure foreman_proxy_plugin_abrt
  38. [✗] Configure foreman_proxy_plugin_ansible
  39. [✗] Configure foreman_proxy_plugin_chef
  40. [✗] Configure foreman_proxy_plugin_dhcp_infoblox
  41. [✗] Configure foreman_proxy_plugin_dhcp_remote_isc
  42. [✗] Configure foreman_proxy_plugin_discovery
  43. [✗] Configure foreman_proxy_plugin_dns_infoblox
  44. [✗] Configure foreman_proxy_plugin_dns_powerdns
  45. [✗] Configure foreman_proxy_plugin_dynflow
  46. [✗] Configure foreman_proxy_plugin_monitoring
  47. [✗] Configure foreman_proxy_plugin_omaha
  48. [✗] Configure foreman_proxy_plugin_openscap
  49. [✗] Configure foreman_proxy_plugin_pulp
  50. [✓] Configure foreman_proxy_plugin_remote_execution_ssh
  51. [✗] Configure foreman_proxy_plugin_salt
  52. Display current config
  53. Save and run
  54. Cancel run without Saving
Here is the output of running yum list installed tfm-rubygem-foreman*
Installed Packages
tfm-rubygem-foreman-tasks.noarch                                  0.10.0-2.fm1_16.el7                  @foreman-plugins
tfm-rubygem-foreman-tasks-core.noarch                             0.2.0-1.fm1_16.el7                   @foreman-plugins
tfm-rubygem-foreman_dhcp_browser.noarch                           0.0.7-3.fm1_11.el7                   @foreman-plugins
tfm-rubygem-foreman_remote_execution.noarch                       1.3.7-1.fm1_15.el7                   @foreman-plugins
tfm-rubygem-foreman_remote_execution_core.noarch                  1.0.6-1.fm1_15.el7                   @foreman-plugins
tfm-rubygem-foreman_setup.noarch                                  5.0.0-1.fm1_13.el7                   @foreman-plugins
tfm-rubygem-foreman_templates.noarch                              5.0.1-1.fm1_16.el7                   @foreman-plugins
So is there any workaround to the packaging issues right now? Or do I need to wait until the RPMs get all fixed up and pushed?
I don’t think this is actually being caused by the OneBox, but rather an interesting combination of email weirdness and parser edge cases. Rather than derail this support topic, I’ll discuss it on the Site Feeback board
@bkrisch here’s the rest of Ivan’s comment as I think he intended it to read:
As I’ve suggested in Deploy dynflow-executor service via Foreman package by dLobatog · Pull Request #1549 · theforeman/foreman-packaging · GitHub, I will revert the changes in tasks that caused this troubles and release a new version that will still ship the service scripts in 1.16
So I guess it’s just a case of waiting for the new version.
