Now i’m trying to upgrade foreman from 3.3 to 3.4. Getting an error while run installer.
# foreman-installer
2022-09-15 11:37:49 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-09-15 11:37:53 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-09-15 11:37:53 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2022-09-15 11:37:59 [NOTICE] [configure] Starting system configuration.
2022-09-15 11:38:10 [NOTICE] [configure] 250 configuration steps out of 1795 steps complete.
2022-09-15 11:38:14 [NOTICE] [configure] 500 configuration steps out of 1795 steps complete.
2022-09-15 11:38:16 [NOTICE] [configure] 750 configuration steps out of 1800 steps complete.
2022-09-15 11:38:17 [NOTICE] [configure] 1250 configuration steps out of 1807 steps complete.
2022-09-15 11:39:08 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Failed to call refresh: '/usr/sbin/foreman-rake db:seed' returned 1 instead of one of [0]
2022-09-15 11:39:08 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: '/usr/sbin/foreman-rake db:seed' returned 1 instead of one of [0]
2022-09-15 11:39:08 [NOTICE] [configure] 1500 configuration steps out of 1807 steps complete.
2022-09-15 11:39:16 [NOTICE] [configure] 1750 configuration steps out of 1807 steps complete.
2022-09-15 11:39:19 [NOTICE] [configure] System configuration has finished.
Below is the db:seed trace output.
# foreman-rake db:seed --trace
Rubocop not loaded.
** Invoke db:seed (first_time)
** Invoke db:load_config (first_time)
** Execute environment
rake aborted!
ActiveModel::UnknownAttributeError: unknown attribute 'description' for Setting::DefaultHostgroup.
/usr/share/gems/gems/activemodel-6.1.6.1/lib/active_model/attribute_assignment.rb:51:in `_assign_attribute'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/attribute_assignment.rb:21:in `block in _assign_attributes'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/attribute_assignment.rb:13:in `each'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/attribute_assignment.rb:13:in `_assign_attributes'
/usr/share/gems/gems/activemodel-6.1.6.1/lib/active_model/attribute_assignment.rb:34:in `assign_attributes'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/core.rb:518:in `initialize'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/inheritance.rb:72:in `new'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/persistence.rb:37:in `create'
/usr/share/gems/gems/foreman_default_hostgroup-6.0.0/app/models/setting/default_hostgroup.rb:16:in `block (2 levels) in load_defaults'
/usr/share/gems/gems/foreman_default_hostgroup-6.0.0/app/models/setting/default_hostgroup.rb:16:in `each'
/usr/share/gems/gems/foreman_default_hostgroup-6.0.0/app/models/setting/default_hostgroup.rb:16:in `block in load_defaults'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/transactions.rb:209:in `transaction'
/usr/share/gems/gems/foreman_default_hostgroup-6.0.0/app/models/setting/default_hostgroup.rb:11:in `load_defaults'
/usr/share/foreman/app/services/setting_registry.rb:114:in `each'
/usr/share/foreman/app/services/setting_registry.rb:114:in `load'
/usr/share/foreman/config/initializers/foreman.rb:37:in `block in <top (required)>'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:427:in `instance_exec'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:427:in `block in make_lambda'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:604:in `block (2 levels) in default_terminator'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:603:in `catch'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:603:in `block in default_terminator'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:199:in `block in halting'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:512:in `block in invoke_before'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:512:in `each'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:512:in `invoke_before'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/callbacks.rb:105:in `run_callbacks'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/reloader.rb:88:in `prepare!'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/application/finisher.rb:124:in `block in <module:Finisher>'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in `instance_exec'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in `run'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `block in run'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:17:in `benchmark'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `run'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/usr/share/ruby/tsort.rb:228:in `block in tsort_each'
/usr/share/ruby/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
/usr/share/ruby/tsort.rb:431:in `each_strongly_connected_component_from'
/usr/share/ruby/tsort.rb:349:in `block in each_strongly_connected_component'
/usr/share/ruby/tsort.rb:347:in `each'
/usr/share/ruby/tsort.rb:347:in `call'
/usr/share/ruby/tsort.rb:347:in `each_strongly_connected_component'
/usr/share/ruby/tsort.rb:226:in `tsort_each'
/usr/share/ruby/tsort.rb:205:in `tsort_each'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/initializable.rb:60:in `run_initializers'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/application.rb:391:in `initialize!'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `public_send'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `method_missing'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>'
/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:83:in `require'
/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in `block in require'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:299:in `load_dependency'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in `require'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/application.rb:367:in `require_environment!'
/usr/share/gems/gems/railties-6.1.6.1/lib/rails/application.rb:533:in `block in run_tasks_blocks'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:199:in `synchronize'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:241:in `each'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:241:in `invoke_prerequisites'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/usr/bin/rake:23:in `load'
/usr/bin/rake:23:in `<main>'
Tasks: TOP => db:seed => db:load_config => environment
i tried to disable foreman_plugin_default_hostgroup, but getting the same error, hence i restored foreman from backup, and disabled foreman_plugin_default_hostgroup.
Now tried upgrade, getting same error even after disable the plugin.
foreman-installer --help | grep -i Hostgroup
–[no-]enable-foreman-plugin-default-hostgroup Enable ‘foreman_plugin_default_hostgroup’ puppet module (default: false)
= Module foreman_plugin_default_hostgroup:
–foreman-plugin-default-hostgroup-hostgroups An array of hashes of hostgroup names and facts to add to the configuration (current: )
It seems another plugin has been hit by the settings change, see the other thread where other two plugins were identified. There’s no good solution atm.
