Expected outcome: I can register hosts in Foreman by setup trough ansible callback or something
Foreman and Proxy versions: 1.18
Hi folks,
Is there a way to import or add a existing System to foreman through ansible ?
Hi folks,
If I understand correctly the plugin documentation, it s possible : Foreman :: Plugin Manuals , but I never did it
It is possible, just configure the callback according to the manual. Also for ansible 2.5 and higher you need to run a playbook to trigger the callback.
