Importing Puppet module to foreman puppet classes ( katello + foreman )
Hello Team,
i have downloaded puppet module from puppet forge …
https://forge.puppetlabs.com/puppetlabs/ntp
Now i am trying to import it to puppet classes, i am able to import
ntp::config, ntp::service, ntp::params, but why i am not seeing NTP class ??
i checked init.pp there is NTP class defined there … also the parameters
passed to NTP class i should see in smart parameters …
i tried another similar module for resov.conf and that works as expected
what i am missing ??
  1. where do i create config/ignored_enviroments.yml file to remove params,
    config, services classes from GUI ??
Regards,
DJ
> Hello Team,
> parameters passed to NTP class i should see in smart parameters …
Which version of Puppet are you running? If you're on 2.6, it might not
parse.
> 2) where do i create config/ignored_enviroments.yml file to remove
> params, config, services classes from GUI ??
In ~foreman, usually /usr/share/foreman.
These questions would be better suited to our users mailing list at
foreman-users@googlegroups.com, where there are more people able to
answer. Thanks!
··· On 18/03/14 16:27, Unix SA wrote:
Dominic Cleal
Red Hat Engineering
