Problem: Is there any documentation on how to use https://forge.puppet.com/katello/katello/9.0.2/readme ? Most of my query results (if not all) are related on how to install katello with or without puppet itself in the same machine, however what I’m trying to achieve is use my existing Foreman and Puppet server to create a class and profile where I can install katello on x desired amount of hosts, I haven’t been able to find a way to do so and my attempts are failing when testing my classes and profiles
Expected outcome: Install/provision katello itself in a determined host using an existing puppet server with a desired role/profile/class instead of going on each node and manually running foreman-installer --scenario katello
Foreman and Proxy versions: 2.0
Foreman and Proxy plugin versions: 2.0
Distribution and version: CentOS 7
Other relevant data: N/A
