I just migrate to a katello instance to install errata (previously we just
used it as a repository.
Within content host view, I can install errata correctly. Tasks tab
indicate task as finished with success, package tab is correctly updated,
but within errata tab it is still indicated as installable …
Is that a normal behavior ? If not, how should I investigate this issue ?
Regards
Yannig Rousseau
OS= Oracle Linux 6.7
package version : katello-2.4.0-7 / pulp-server-2.6.4-1 / foreman-1.10.2-1
In case anyone is interested.
The task which recalculate "installable errata" depending on installed
package is : Generate applicability {"services_checked"=>…
<https://pebinvnuxapp02/foreman_tasks/tasks/727c9a0c-730e-4e62-a027-9d62a958a95c>
This task seems to be automatically launched at the end of an successfull
"Install erratum" task or when installing / removing package on
content-host manually, but it will update only for the installed / removed
package.
On my instance those task were correctly generated but failed with error
Trying to use logger katello/pulp_rest which has not been configured.
With an update of my server + a reboot, pulp seems to function better now
but I don't know what was originally the issue. If I resume one of the
failed task, it does finish correctly & update the installable errata list.
My issue now is : How to update massively for all package / content-host
(other than manually restarting "Generate applicability" tasks) ??
Regards
On Wednesday, 7 December 2016 11:36:03 UTC+1, yannig rousseau wrote:
> Hi all,
> but within errata tab it is still indicated as installable ...
> Regards
> Yannig Rousseau
On Dec 8, 2016 5:47 AM, "yannig rousseau" wrote:
Hi all,
The task which recalculate “installable errata” depending on installed
package is : Generate applicability {“services_checked”=>… https://pebinvnuxapp02/foreman_tasks/tasks/727c9a0c-730e-4e62-a027-9d62a958a95c
“Install erratum” task or when installing / removing package on
package.
but I don’t know what was originally the issue. If I resume one of the
(other than manually restarting “Generate applicability” tasks) ??
Regards
Hi all,
just used it as a repository.
Regards
Yannig Rousseau
On Thursday, 8 December 2016 14:04:22 UTC+1, Eric Helms wrote:
> What version of Katello are you running?
> On Dec 8, 2016 5:47 AM, "yannig rousseau" > wrote:
>> Hi all,
>> package is :
>> *Generate applicability {"services_checked"=>...
>> package.
>> Regards
>>> Hi all,
>>> Regards
>>> Yannig Rousseau
>>> foreman-1.10.2-1
>> "Foreman users" group.
>> Visit this group at https://groups.google.com/group/foreman-users.
