Cheers, I am attempting to install 3.1 on CentOS 8 Stream without Puppet, but running into issues with group “puppet” does not exist. I will workaround this by creating the group manually, but just to let you know:
[root@zzzap ~]# if [[ "$SCENARIO" == "satellite" ]]; then
> export INSTALLER_OPTS=<<EOF
> --foreman-proxy-content-pulpcore-worker-count 2
> EOF
> else
> --enable-foreman-compute-libvirt true
> --foreman-proxy-plugin-discovery-install-images true
> EOF
> fi
[root@zzzap ~]# $SCENARIO-installer --skip-checks-i-know-better --verbose --scenario $SCENARIO \
> --foreman-initial-organization "$ORG" \
> --foreman-initial-location "$LOC" \
> --foreman-initial-admin-password changeme \
> --foreman-initial-admin-locale en_US \
> --no-enable-puppet \
> --enable-foreman-plugin-bootdisk \
> --enable-foreman-plugin-webhooks \
> --enable-foreman-proxy-plugin-shellhooks \
> --foreman-proxy-dns true \
> --foreman-proxy-dns-forwarders ${SUBNET}.1 \
> --foreman-proxy-dns-zone $DOMAIN \
> --foreman-proxy-dns-reverse ${REVERSE}.in-addr.arpa \
> --foreman-proxy-dhcp true \
> --foreman-proxy-dhcp-gateway=${SUBNET}.1 \
> --foreman-proxy-dhcp-range="${SUBNET}.50 ${SUBNET}.150" \
> --foreman-proxy-dhcp-nameservers="${IP}" \
> --foreman-proxy-tftp true \
> --foreman-proxy-tftp-servername=${IP} \
> $INSTALLER_OPTS
2022-01-07 08:19:13 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-01-07 08:19:16 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-01-07 08:19:16 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2022-01-07 08:19:55 [NOTICE] [configure] Starting system configuration.
2022-01-07 08:21:10 [NOTICE] [configure] 250 configuration steps out of 1129 steps complete.
2022-01-07 08:21:10 [ERROR ] [configure] Could not set groups on user[foreman]: Execution of '/sbin/usermod -G puppet foreman' returned 6: usermod: group 'puppet' does not exist
2022-01-07 08:21:10 [ERROR ] [configure] /Stage[main]/Foreman::Config/User[foreman]/groups: change from to 'puppet' failed: Could not set groups on user[foreman]: Execution of '/sbin/usermod -G puppet foreman' returned 6: usermod: group 'puppet' does not exist
2022-01-07 08:22:20 [ERROR ] [configure] Could not set groups on user[foreman-proxy]: Execution of '/sbin/usermod -G named,puppet foreman-proxy' returned 6: usermod: group 'puppet' does not exist
2022-01-07 08:22:20 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Config/User[foreman-proxy]/groups: change from to 'named,puppet' failed: Could not set groups on user[foreman-proxy]: Execution of '/sbin/usermod -G named,puppet foreman-proxy' returned 6: usermod: group 'puppet' does not exist
2022-01-07 08:22:31 [NOTICE] [configure] 500 configuration steps out of 1131 steps complete.
2022-01-07 08:22:57 [NOTICE] [configure] 750 configuration steps out of 1139 steps complete.
2022-01-07 08:23:06 [NOTICE] [configure] 1000 configuration steps out of 1161 steps complete.
2022-01-07 08:23:18 [NOTICE] [configure] System configuration has finished.
The full log is at /var/log/foreman-installer/foreman.log
Weird there is some inconsistency between Ruby and Puppet:
[root@zzzap ~]# dnf install puppet
Last metadata expiration check: 1:13:16 ago on Fri 07 Jan 2022 07:28:28 AM CET.
Error:
Problem: package puppet-6.25.1-1.el8.noarch requires ruby(selinux), but none of the providers can be installed
- package libselinux-ruby-2.9-5.el8.x86_64 requires libruby.so.2.5()(64bit), but none of the providers can be installed
- conflicting requests
- package ruby-libs-2.5.5-105.module_el8.1.0+214+9be47fd7.x86_64 is filtered out by modular filtering
- package ruby-libs-2.5.9-107.module_el8.5.0+811+d98a1657.x86_64 is filtered out by modular filtering
That looks like you’re installing puppet from EPEL which we don’t support.
This is incomplete. You’re missing --foreman-proxy-puppet false --foreman-proxy-puppetca false.
It looks like you’re installing Foreman without Puppet but the default foreman scenario relies on Puppet as a CA to generate certificates. If you don’t want Puppet, you must provide Foreman and Foreman Proxy with other certificates.
I have been wanting to write a blog about this for about 2 years but it hasn’t gotten out of draft so I’ll share the relevant bits. Here I assume in /etc/ownca there are certificates.
Indeed, it’s only an issue in Foreman without Katello and hat @lzap said is correct. To expand on that: Katello has its own CA generated with katello-certs-tools. Technically it’s not Candlepin that generates the certificates used in the infrastructure but rather Candlepin gets the CA certificate from that tool. Candlepin only creates certificates for actual clients.
If you won’t get to the full blog, would it make sense to convert this to the Tutorials - TheForeman? I think it would be easier for users to find the magic installer command in there.
