ahoiHGF
November 10, 2022, 12:31pm
#1
I want to install the remote execution plugin on a foreman-proxy, which fails during installation.
2022-11-10 13:26:29 [ERROR ] [configure] Evaluation Error: Error while evaluating a Method call, 'regsubst' parameter 'target' expects a value of type Array or String, got Undef (file: /usr/share/foreman-installer/modules/foreman/manifests/plugin/tasks.pp, line: 18, column: 56) on node proxy1.example.org
and
2022-11-10 13:26:29 [DEBUG ] [configure] Unknown variable: 'foreman::params::plugin_prefix'. (file: /usr/share/foreman-installer/modules/foreman/manifests/plugin/tasks.pp, line: 18, column: 16)
2022-11-10 13:26:29 [ERROR ] [configure] Evaluation Error: Error while evaluating a Method call, 'regsubst' parameter 'target' expects a value of type Array or String, got Undef (file: /usr/share/foreman-installer/modules/foreman/manifests/plugin/tasks.pp, line: 18, column: 56) on proxy1.example.org
Working remote execution plugin.
Version
3.0.2
Active features
Discovery
Dynflow
Logs
Puppet
Puppet CA
Registration
SSH
Templates
TFTP
Discovery
Version
1.0.5
Dynflow
Version
0.5.2
Registration
Version
3.0.2
SSH
Version
0.4.1
TFTP
Version
3.0.2
TFTP server
false
Templates
Version
3.0.2
evgeni
November 10, 2022, 12:32pm
#2
The proxy only needs the proxy plugin, not the foreman plugin which you seem to be enabling.
What is your Installer command line?
ahoiHGF
November 10, 2022, 12:39pm
#3
I used:
foreman-installer --enable-foreman-plugin-remote-execution --enable-foreman-proxy-plugin-remote-execution-ssh
This is the /etc/foreman-installer/scenarios.d/foreman-answers.yaml
# Format:
# <classname>: false - don't include this class
# <classname>: true - include and use the defaults
# <classname>:
# <param>: <value> - include and override the default(s)
# See params.pp in each class for what options are available
foreman: false
foreman::cli: false
foreman::cli::ansible: false
foreman::cli::azure: false
foreman::cli::discovery: false
foreman::cli::kubevirt: false
foreman::cli::openscap: false
foreman::cli::puppet: false
foreman::cli::remote_execution: false
foreman::cli::tasks: false
foreman::cli::templates: false
foreman::cli::webhooks: false
foreman_proxy:
version: present
ensure_packages_version: present
bind_host:
http_port: 8000
ssl_port: 8443
groups: []
log: "/var/log/foreman-proxy/proxy.log"
log_level: INFO
log_buffer: 2000
log_buffer_errors: 1000
http: true
ssl: true
ssl_ca: "/etc/foreman-proxy/ca.pem"
ssl_cert: "/etc/foreman-proxy/cert.pem"
ssl_key: "/etc/foreman-proxy/key.pem"
foreman_ssl_ca: "/etc/foreman-proxy/ca.pem"
foreman_ssl_cert: "/etc/foreman-proxy/cert.pem"
foreman_ssl_key: "/etc/foreman-proxy/key.pem"
trusted_hosts:
- foreman.example.org
ssl_disabled_ciphers: []
tls_disabled_versions: []
manage_sudoersd: true
use_sudoersd: true
use_sudoers: true
puppetca: true
puppetca_listen_on: https
ssldir: "/etc/puppetlabs/puppet/ssl"
puppetdir: "/etc/puppetlabs/puppet"
puppetca_cmd: "/opt/puppetlabs/bin/puppet cert"
puppet_group: puppet
puppetca_provider: puppetca_hostname_whitelisting
autosignfile: "/etc/puppetlabs/puppet/autosign.conf"
puppetca_sign_all: false
puppetca_tokens_file: "/var/lib/foreman-proxy/tokens.yml"
puppetca_token_ttl: 360
puppetca_certificate:
manage_puppet_group: true
puppet: true
puppet_listen_on: https
puppet_url: https://proxy1.example.org:8140
puppet_ssl_ca: "/etc/puppetlabs/puppet/ssl/certs/ca.pem"
puppet_ssl_cert: "/etc/puppetlabs/puppet/ssl/certs/proxy1.example.org.pem"
puppet_ssl_key: "/etc/puppetlabs/puppet/ssl/private_keys/proxy1.example.org.pem"
puppet_api_timeout: 30
templates: true
templates_listen_on: both
template_url: http://proxy1.example.org:8000
registration: true
registration_listen_on: https
logs: true
logs_listen_on: https
httpboot: false
httpboot_listen_on: both
tftp: true
tftp_listen_on: https
tftp_managed: true
tftp_manage_wget: true
tftp_syslinux_filenames:
- "/usr/share/syslinux/chain.c32"
- "/usr/share/syslinux/mboot.c32"
- "/usr/share/syslinux/menu.c32"
- "/usr/share/syslinux/memdisk"
- "/usr/share/syslinux/pxelinux.0"
tftp_root: "/var/lib/tftpboot"
tftp_dirs:
- "/var/lib/tftpboot/pxelinux.cfg"
- "/var/lib/tftpboot/grub"
- "/var/lib/tftpboot/grub2"
- "/var/lib/tftpboot/boot"
- "/var/lib/tftpboot/ztp.cfg"
- "/var/lib/tftpboot/poap.cfg"
tftp_servername:
tftp_replace_grub2_cfg: false
dhcp: false
dhcp_listen_on: https
dhcp_managed: true
dhcp_provider: isc
dhcp_subnets: []
dhcp_ping_free_ip: true
dhcp_option_domain:
- example.org
dhcp_search_domains:
dhcp_interface: ens32
dhcp_additional_interfaces: []
dhcp_gateway:
dhcp_range:
dhcp_pxeserver:
dhcp_pxefilename: pxelinux.0
dhcp_network:
dhcp_netmask:
dhcp_nameservers: default
dhcp_server: 127.0.0.1
dhcp_config: "/etc/dhcp/dhcpd.conf"
dhcp_leases: "/var/lib/dhcpd/dhcpd.leases"
dhcp_key_name:
dhcp_key_secret:
dhcp_omapi_port: 7911
dhcp_peer_address:
dhcp_node_type: standalone
dhcp_failover_address: 10.11.50.50
dhcp_failover_port: 519
dhcp_max_response_delay: 30
dhcp_max_unacked_updates: 10
dhcp_mclt: 300
dhcp_load_split: 255
dhcp_load_balance: 3
dhcp_manage_acls: true
dns: false
dns_listen_on: https
dns_managed: true
dns_provider: nsupdate
dns_interface: ens32
dns_zone: example.org
dns_reverse:
dns_server: 127.0.0.1
dns_ttl: 86400
dns_tsig_keytab: "/etc/foreman-proxy/dns.keytab"
dns_tsig_principal: foremanproxy/proxy1.example.org@HOGREFE.DE
dns_forwarders: []
libvirt_network: default
libvirt_connection: qemu:///system
bmc: false
bmc_listen_on: https
bmc_default_provider: ipmitool
bmc_ssh_user: root
bmc_ssh_key: "/usr/share/foreman/.ssh/id_rsa"
bmc_ssh_powerstatus: 'true'
bmc_ssh_powercycle: shutdown -r +1
bmc_ssh_poweroff: shutdown +1
bmc_ssh_poweron: 'false'
realm: false
realm_listen_on: https
realm_provider: freeipa
realm_keytab: "/etc/foreman-proxy/freeipa.keytab"
realm_principal: realm-proxy@EXAMPLE.COM
freeipa_config: "/etc/ipa/default.conf"
freeipa_remove_dns: true
keyfile: "/etc/rndc.key"
register_in_foreman: true
foreman_base_url: https://foreman.example.org
registered_name: proxy1.example.org
registered_proxy_url:
oauth_effective_user: admin
oauth_consumer_key: c4ay2TbSGSaF4nMZ9wYR3Hs7em8Mpaw2
oauth_consumer_secret: JKVPDK23GtU52yyUZXB4PQqfuFp9Htg2
puppet:
version: present
user: puppet
group: puppet
codedir: "/etc/puppetlabs/code"
vardir: "/opt/puppetlabs/puppet/cache"
logdir: "/var/log/puppetlabs/puppet"
rundir: "/var/run/puppetlabs"
sharedir: "/opt/puppetlabs/puppet"
manage_packages: true
dir_owner: root
dir_group:
package_provider:
package_install_options:
package_source:
port: 8140
pluginsync: true
splay: false
splaylimit: 1800
autosign: "/etc/puppetlabs/puppet/autosign.conf"
autosign_entries: []
autosign_mode: '0664'
autosign_content:
autosign_source:
runinterval: 1800
usecacheonfailure: true
runmode: service
run_hour:
run_minute:
unavailable_runmodes: []
cron_cmd:
systemd_cmd:
systemd_randomizeddelaysec: 0
agent_noop: false
show_diff: false
module_repository:
http_connect_timeout:
http_read_timeout:
ca_server:
ca_port:
ca_crl_filepath:
prerun_command:
postrun_command:
dns_alt_names: []
use_srv_records: false
srv_domain: example.org
pluginsource: puppet:///plugins
pluginfactsource: puppet:///pluginfacts
additional_settings: {}
agent_additional_settings: {}
agent_restart_command: "/usr/bin/systemctl reload-or-restart puppet"
classfile: "$statedir/classes.txt"
hiera_config: "$confdir/hiera.yaml"
auth_template: puppet/auth.conf.erb
allow_any_crl_auth: false
auth_allowed:
- "$1"
client_package:
- puppet-agent
agent: true
remove_lock: true
report: true
client_certname: proxy1.example.org
puppetmaster:
systemd_unit_name: puppet-run
service_name: puppet
syslogfacility:
environment: production
server: true
server_admin_api_whitelist:
- localhost
- proxy1.example.org
server_manage_user: true
server_user: puppet
server_group: puppet
server_dir: "/etc/puppetlabs/puppet"
server_ip: 0.0.0.0
server_port: 8140
server_ca: true
server_ca_crl_sync: false
server_crl_enable:
server_ca_auth_required: true
server_ca_client_self_delete: false
server_ca_client_whitelist:
- localhost
server_custom_trusted_oid_mapping:
server_http: false
server_http_port: 8139
server_reports: foreman
server_puppetserver_dir: "/etc/puppetlabs/puppetserver"
server_puppetserver_vardir: "/opt/puppetlabs/server/data/puppetserver"
server_puppetserver_rundir: "/var/run/puppetlabs/puppetserver"
server_puppetserver_logdir: "/var/log/puppetlabs/puppetserver"
server_puppetserver_version:
server_external_nodes: "/etc/puppetlabs/puppet/node.rb"
server_trusted_external_command:
server_cipher_suites:
- TLS_RSA_WITH_AES_256_CBC_SHA256
- TLS_RSA_WITH_AES_128_CBC_SHA256
server_config_version:
server_connect_timeout: 120000
server_git_repo: false
server_default_manifest: false
server_default_manifest_path: "/etc/puppet/manifests/default_manifest.pp"
server_default_manifest_content: ''
server_environments_owner: puppet
server_environments_group:
server_environments_mode: '0755'
server_envs_dir: "/etc/puppetlabs/code/environments"
server_envs_target:
server_common_modules_path:
- "/etc/puppetlabs/code/environments/common"
- "/etc/puppetlabs/code/modules"
- "/opt/puppetlabs/puppet/modules"
- "/usr/share/puppet/modules"
server_git_repo_mode: '0755'
server_git_repo_path: "/opt/puppetlabs/puppet/cache/puppet.git"
server_git_repo_group: puppet
server_git_repo_user: puppet
server_git_branch_map: {}
server_idle_timeout: 1200000
server_post_hook_content: puppet/server/post-receive.erb
server_post_hook_name: post-receive
server_storeconfigs: false
server_ruby_load_paths:
- "/opt/puppetlabs/puppet/lib/ruby/vendor_ruby"
server_ssl_dir: "/etc/puppetlabs/puppet/ssl"
server_ssl_dir_manage: true
server_ssl_key_manage: true
server_ssl_protocols:
- TLSv1.2
server_ssl_chain_filepath:
server_package:
server_version:
server_certname: proxy1.example.org
server_request_timeout: 60
server_strict_variables: false
server_additional_settings: {}
server_foreman: true
server_foreman_url: https://foreman.example.org
server_foreman_ssl_ca: "/etc/foreman-proxy/ca.pem"
server_foreman_ssl_cert: "/etc/foreman-proxy/cert.pem"
server_foreman_ssl_key: "/etc/foreman-proxy/key.pem"
server_foreman_facts: true
server_puppet_basedir: "/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet"
server_parser: current
server_environment_timeout:
server_jvm_java_bin: "/usr/bin/java"
server_jvm_config: "/etc/sysconfig/puppetserver"
server_jvm_min_heap_size: 2G
server_jvm_max_heap_size: 2G
server_jvm_extra_args:
- "-Djruby.logger.class=com.puppetlabs.jruby_utils.jruby.Slf4jLogger"
- "-XX:ReservedCodeCacheSize=512m"
server_jvm_cli_args:
server_jruby_gem_home: "/opt/puppetlabs/server/data/puppetserver/jruby-gems"
server_max_active_instances: 4
server_max_requests_per_instance: 0
server_max_queued_requests: 0
server_max_retry_delay: 1800
server_multithreaded: false
server_use_legacy_auth_conf: false
server_check_for_updates: true
server_environment_class_cache_enabled: false
server_allow_header_cert_info: false
server_web_idle_timeout: 30000
server_puppetserver_jruby9k: false
server_puppetserver_metrics: false
server_puppetserver_profiler: false
server_metrics_jmx_enable: true
server_metrics_graphite_enable: false
server_metrics_graphite_host: 127.0.0.1
server_metrics_graphite_port: 2003
server_metrics_server_id: proxy1.example.org
server_metrics_graphite_interval: 5
server_metrics_allowed:
server_puppetserver_experimental: true
server_puppetserver_auth_template:
server_puppetserver_trusted_agents: []
server_puppetserver_trusted_certificate_extensions: []
server_compile_mode:
server_acceptor_threads:
server_selector_threads:
server_ssl_acceptor_threads:
server_ssl_selector_threads:
server_max_threads:
server_ca_allow_sans: false
server_ca_allow_auth_extensions: false
server_ca_enable_infra_crl: false
server_max_open_files:
server_versioned_code_id:
server_versioned_code_content:
foreman::plugin::acd: false
foreman::plugin::ansible: false
foreman::plugin::azure: false
foreman::plugin::bootdisk: false
foreman::plugin::chef: false
foreman::plugin::column_view: false
foreman::plugin::default_hostgroup: false
foreman::plugin::dhcp_browser: false
foreman::plugin::discovery: false
foreman::plugin::expire_hosts: false
foreman::plugin::hooks: false
foreman::plugin::host_extra_validator: false
foreman::plugin::kubevirt: false
foreman::plugin::leapp: false
foreman::plugin::memcache: false
foreman::plugin::monitoring: false
foreman::plugin::omaha: false
foreman::plugin::openscap: false
foreman::plugin::ovirt_provision: false
foreman::plugin::puppet: false
foreman::plugin::puppetdb: false
foreman::plugin::remote_execution: {}
foreman::plugin::remote_execution::cockpit: false
foreman::plugin::salt: false
foreman::plugin::setup: false
foreman::plugin::snapshot_management: false
foreman::plugin::statistics: false
foreman::plugin::tasks: false
foreman::plugin::templates: false
foreman::plugin::webhooks: false
foreman::compute::ec2: false
foreman::compute::gce: false
foreman::compute::libvirt: false
foreman::compute::openstack: false
foreman::compute::ovirt: false
foreman::compute::vmware: false
foreman_proxy::plugin::acd: false
foreman_proxy::plugin::ansible: false
foreman_proxy::plugin::chef: false
foreman_proxy::plugin::dhcp::infoblox: false
foreman_proxy::plugin::dhcp::remote_isc: false
foreman_proxy::plugin::discovery:
install_images: true
source_url: http://downloads.theforeman.org/discovery/releases/latest/
image_name: fdi-image-latest.tar
foreman_proxy::plugin::dns::infoblox: false
foreman_proxy::plugin::dns::powerdns: false
foreman_proxy::plugin::dynflow: false
foreman_proxy::plugin::monitoring: false
foreman_proxy::plugin::omaha: false
foreman_proxy::plugin::openscap: false
foreman_proxy::plugin::remote_execution::ssh:
enabled: true
listen_on: https
generate_keys: true
install_key: false
ssh_identity_dir: "/var/lib/foreman-proxy/ssh"
ssh_identity_file: id_rsa_foreman_proxy
ssh_keygen: "/usr/bin/ssh-keygen"
local_working_dir: "/var/tmp"
remote_working_dir: "/var/tmp"
ssh_kerberos_auth: false
async_ssh: false
foreman_proxy::plugin::salt: false
foreman_proxy::plugin::shellhooks: false
and this is the version I used before trying to install the plugin: This does not produce any errors:
# Format:
# <classname>:
foreman: false
foreman::cli: false
foreman_proxy:
version: present
bind_host:
http_port: 8000
ssl_port: 8443
groups: []
log_level: INFO
log_buffer: 2000
http: true
ssl: true
trusted_hosts:
use_sudoersd: true
use_sudoers: true
puppetca: true
puppet: true
templates: true
registration: true
logs: true
httpboot: false
tftp: true
tftp_managed: true
tftp_dirs:
tftp_servername:
dhcp: false
dhcp_managed: true
dhcp_provider: isc
dhcp_subnets: []
dhcp_option_domain:
- example.org
dhcp_gateway:
dhcp_range:
dhcp_pxeserver:
dhcp_network:
dhcp_netmask:
dhcp_key_name:
dhcp_key_secret:
dhcp_peer_address:
dhcp_mclt: 300
dns: false
dns_managed: true
dns_reverse:
dns_ttl: 86400
dns_forwarders: []
bmc: false
bmc_ssh_user: root
realm: false
puppet:
version: present
user: puppet
group: puppet
dir_owner: root
dir_group:
package_provider:
package_source:
port: 8140
pluginsync: true
splay: false
splaylimit: 1800
autosign_content:
autosign_source:
runinterval: 1800
runmode: service
run_hour:
run_minute:
cron_cmd:
systemd_cmd:
agent_noop: false
show_diff: false
module_repository:
http_read_timeout:
ca_server:
ca_port:
ca_crl_filepath:
prerun_command:
postrun_command:
dns_alt_names: []
auth_allowed:
- "$1"
client_package:
- puppet-agent
agent: true
remove_lock: true
report: true
puppetmaster:
syslogfacility:
server: true
- localhost
server_user: puppet
server_ip: 0.0.0.0
server_port: 8140
server_ca: true
server_crl_enable:
- localhost
server_http: false
server_envs_target:
- TLSv1.2
server_package:
server_version:
server_max_threads:
foreman::plugin::remote_execution: false
foreman_proxy::plugin::remote_execution::ssh: false
evgeni
November 11, 2022, 9:08am
#4
Right, but --enable-foreman-plugin-remote-execution
is for the Foreman plugin, you do not want that. You only need --enable-foreman-proxy-plugin-remote-execution-ssh
Can you give it another run with --no-enable-foreman-plugin-remote-execution
