# Place this file in you /etc/yum.repos.d/ folder
[vdsm-dre]
name=Vdsm repo
baseurl=http://www.dreyou.org/ovirt/vdsm/
http://www1.dreyou.org/ovirt/vdsm/
enabled=0
gpgcheck=0
Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.com het volgende:
I “had” a decent install of oVirt on my system and wanted to install
Foreman with it.
Because my install is running on CentOS, and I wanted to try The Foreman
and am a Ubuntu user most of the time, I would like to use a script that
installs all needed packages, like Ubuntu/Debian does but it’s own.
I found the following script that doesn’t work that good anymore and
removes the oVirt installation:
The second URL should be space-indented to indicate a line continuation.
This is tripping up the Puppet parsedfile parser, but perhaps yum is
simply ignoring it.
Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.com > het volgende:
I "had" a decent install of oVirt on my system and wanted to install
Foreman with it.
Foreman and am a Ubuntu user most of the time, I would like to use a
script that installs all needed packages, like Ubuntu/Debian does
but it's own.
I found the following script that doesn't work that good anymore and
http://www.uncompiled.com/centos-6-puppet-27-mcollective-foreman-rabbit
<http://www.uncompiled.com/centos-6-puppet-27-mcollective-foreman-rabbit>
The forman repo was kinda simple to fix, but at the end I get a lot
of errors.
It would be nice to have some script that install the right packages
on CentOS.
Does someone have something available ?
Cheers,
Matt
Now you say so indeed, that could have been the issue. (Debian/Ubuntu has
it the same way in their sources.list)
No errors so far.
Cheers,
Matt
Op dinsdag 18 december 2012 17:42:01 UTC+1 schreef Dominic Cleal het volgende:
> simply ignoring it.
> Dominic Cleal
> Red Hat Engineering
> On 18/12/12 16:38, yamaka...@gmail.com wrote:
> > Hi Domenic,
> > The Repo worked perfectly everytime:
> > [vdsm-dre]
> > name=Vdsm repo
> > enabled=0
> > gpgcheck=0
> > [ovirt-dre]
> > name=oVirt engine repo
> > baseurl=http://www.dreyou.org/ovirt/ovirt-engine/
> > http://www1.dreyou.org/ovirt/ovirt-engine/
> > enabled=0
> > gpgcheck=0
> > [vdsm31-dre]
> > name=Vdsm for oVirt 3.1 repo
> > baseurl=http://www.dreyou.org/ovirt/vdsm31/
> > http://www1.dreyou.org/ovirt/vdsm31/
> > enabled=1
> > gpgcheck=0
> > [ovirt31-dre]
> > name=oVirt 3.1 engine repo
> > baseurl=http://www.dreyou.org/ovirt/ovirt-engine31/
> > http://www1.dreyou.org/ovirt/ovirt-engine31/
> > enabled=1
> > gpgcheck=0
> > Op dinsdag 18 december 2012 15:58:46 UTC+1 schreef yamaka...@gmail.com > > het volgende:
> > Foreman with it.
> > but it's own.
> > of errors.
> > on CentOS.
> > Cheers,
> > Matt
> > You received this message because you are subscribed to the Google
> > Groups "Foreman users" group.
> > To view this discussion on the web visit
> > https://groups.google.com/d/msg/foreman-users/-/-zFeo5RdCpMJ.
> > To post to this group, send email to forema...@googlegroups.com.
> > To unsubscribe from this group, send email to
> > foreman-user...@googlegroups.com .
> > For more options, visit this group at
> > http://groups.google.com/group/foreman-users?hl=en.
