Matt,
The foreman-installer [1] is the recommended way to get up and running quickly. It uses a basic Puppet installation (you only need puppet itself w/o any configuration) to setup whichever pieces of infrastructure you might need, including a Puppetmaster, Foreman, the proxy, etc.
Hope that helps!
-Sam
----- Original Message ----- From: "yamakasi 014" To: foreman-users@googlegroups.com Sent: Tuesday, December 18, 2012 9:58:46 AM Subject: [foreman-users] Installation script CentOS6 (with oVirt)I “had” a decent install of oVirt on my system and wanted to install Foreman with it.
Because my install is running on CentOS, and I wanted to try The Foreman and am a Ubuntu user most of the time, I would like to use a script that installs all needed packages, like Ubuntu/Debian does but it’s own.
I found the following script that doesn’t work that good anymore and removes the oVirt installation:
http://www.uncompiled.com/centos-6-puppet-27-mcollective-foreman-rabbit
The forman repo was kinda simple to fix, but at the end I get a lot of errors.
It would be nice to have some script that install the right packages on CentOS.
Does someone have something available ?
Cheers,
Matt
To view this discussion on the web visit https://groups.google.com/d/msg/foreman-users/-/hv_XJbYnoAwJ .
To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
