I’m trying to install the katello-agent on CentOS6 using the instructions at https://www.theforeman.org/plugins/katello/3.9/installation/clients.html.
I’m getting the following dependency error:
-> Running transaction check
—> Package python-pulp-common.noarch 0:2.18.0-2.el6 will be installed
–> Processing Dependency: python-isodate >= 0.5.0-1.pulp for package: python-pulp-common-2.18.0-2.el6.noarch
—> Package qpid-proton-c.x86_64 0:0.24.0-1.el6 will be installed
–> Finished Dependency Resolution
Error: Package: python-pulp-common-2.18.0-2.el6.noarch (pulp)
Requires: python-isodate >= 0.5.0-1.pulp
Available: python-isodate-0.4.7-1.el6.noarch (epel)
python-isodate = 0.4.7-1.el6
Uploading Enabled Repositories Report
Where do I get python-isodate-0.5.0-1 for CentOS6? It’s not in EPEL. I see it in this repository which is listed in the katello 3.8 client install instructions
(https://fedorapeople.org/groups/katello/releases/yum/3.8/client/el6/x86_64/) but not in the repos listed in the katello 3.9 client install instructions.
Thanks!
Nicole
